S32K FlexNVM
S32K FlexNVM
1,819 次查看
wanglijun
I am using S32K148 FlexNVM, and I enabled CSEC key and I also use data flash.
If I enabled the CSEC key, I can't erase flex NVM by debugger erase command.
About the data flash, can I erase the data flash part by FTFC?
0 回复数
