Re: Footprint related query - PCA9554ADB,118.
2,380 次查看
Mohank488
Hi ,
I have query related to this part number PCA9554ADB,118.
In the datasheet component is having 16 pins while the land pattern is having 18 pins. which one I need to consider component pin information or land pattern.
I would request you to kindly provide solution for  the query  ASAP.
Thanks & Regards,
Mohan Kumar N
Krypton solutions India pvt ltd
2,360 次查看
guoweisun
Had replied to you based on your case.
