RD33771-48VEVM Reference Design
NewStarter
this issue has been pending for over 2 months, please help. below is my application diagram, when a battery connects a load which in series with "shunt" R470, battery's ground should be connects with EVB's ground which shound be a big pad of ground becuase the current flow is high.
But I don't see any pad ground on EVB, please suggest
in general when use suggested battery emulator by NXP's website, the battery emulator is conencted with J3 but it will be an issue that battery's power doesn't connect to "shunt" R470, so how can shunt to detect battery's current?
hopefully someone can answer my questions, thanks
