P1022NXN2HFB ref clk
1,410 次查看
zachary_pecze
Would you be able to tell me if the PCIe reference clock is needed if the PCIe system on the P1022NXN2HFB device is not beng used?
1 回复
1,363 次查看
Bulat
If a Serdes is not used, its reference clock is not needed.
Note that settings of cfg_serdes_ports[0:4] allow  to disable Serdes1 or Serdes2 or both.
Bulat
