MRFX035H S-Parameters
Stephan_Orzada
I have a question regarding the S-parameters provided for the MRFX035:
I had used the S-paramters to match the MRFX035H to 300 MHz, but when I use the resulting circuit in real life, the matching is completely off. Are the S-Parameters provided on the web-page actually correct?
When I simulate the 230MHz reference board from the Datasheet using the S-parameters, the results show that it is matched for ~300 MHz. So something seems to be wrong there.
I'm using this file:
! 12/17/2018
! Rev 0
! MRFX035H S-Parameters
! Vdd=65V, IDQ=150mA
%3CLINGO-SUB%20id%3D%22lingo-sub-2162699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMRFX035H%20S-Parameters%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20a%20question%20regarding%20the%20S-parameters%20provided%20for%20the%20MRFX035%3A%3C%2FP%3E%3CP%3EI%20had%20used%20the%20S-paramters%20to%20match%20the%20MRFX035H%20to%20300%20MHz%2C%20but%20when%20I%20use%20the%20resulting%20circuit%20in%20real%20life%2C%20the%20matching%20is%20completely%20off.%20Are%20the%20S-Parameters%20provided%20on%20the%20web-page%20actually%20correct%3F%3C%2FP%3E%3CP%3EWhen%20I%20simulate%20the%20230MHz%20reference%20board%20from%20the%20Datasheet%20using%20the%20S-parameters%2C%20the%20results%20show%20that%20it%20is%20matched%20for%20~300%20MHz.%20So%20something%20seems%20to%20be%20wrong%20there.%3C%2FP%3E%3CP%3EI'm%20using%20this%20file%3A%3C%2FP%3E%3CP%3E!%2012%2F17%2F2018%3CBR%20%2F%3E!%20Rev%200%3CBR%20%2F%3E!%20MRFX035H%20S-Parameters%3CBR%20%2F%3E!%20Vdd%3D65V%2C%20IDQ%3D150mA%3C%2FP%3E%3C%2FLINGO-BODY%3E
