MPC5777C
MPC5777C
PENGHAN
Hello
I would like to consult, use the TRACE32 development environment, connect to the development board through the JTAG port, the program is programmed in the board, why can’t I upload the program?
Thank you!
Regrads
PengHan
lukaszadrapa
I will need more information. Do you have your own board or our EVB? Did it work before? Are you able to enter debug mode? What kind of error can you see in message area?
Lukas
