How to get a voice command to the SLN-Local2-IOT to close contacts briefly
1,337件の閲覧回数
Yooper
I want to create a simple solution where a voice command is issued and processed by the SLN-LOCAL2-IOT and as a result of that command a set of contacts are closed for a brief period. How does one interface to the SLN-LOCAL2-IOT so when a command is issued an SSR is controlled or perhaps some native contacts are closed for a predetermined length of time.
0 返答(返信)
