Volansys Modular Gateway Demo
IoT Physical Components
Gateways
SoC
i.MX 6UltraLite
Picture3.png                             Volansys Modular Gateway
NXP Modules Supported
PN7120 NFC, JN5169 ZigBee
Protocols Supported
ZigBee, Thread, Bluetooth, Wi-Fi
User Compatibility
MikroBus™ Compatible
Network Connectivity
Ethernet, Wi-Fi
Form Factor
100mm x 150mm
Applications
Smart Home
Smart Building
Smart Security
Smart Healthcare
Smart Energy
SOM MODULE
SoC
i.MX 6UltraLite
               Volansys i.MX6UL SOM for Modular Gateway
Memory
DRAM, DDR3, NAND Flash, EEPROM, eMMC
I/O Interfaces
CAN, I2C, SPI, UART, SDIO, PWM, JTAG, SAI, S/PDIF
Form Factor
67.6mm x 45.0mm x 5.0mm
Applications
Energy management Systems
IoT gateway Solutions
Industrial HMI & Access Control
Industrial control & automation
Medical & Healthcare equipment
Smart appliances
Mobile POS & Secure e-commerce
KW2XD Module
SoC
MKW24D512
kw2xd.pngVolansys KW24D Module (for use with Modular Gateway) or Edge Devices
Kinetis® KW2xD
Applications
Smart Energy
M2M
Automated meter reading
Medical Network
HVAC Control
Lighting control
Asset tracking
Environment monitoring and control
Protocols Supported
Thread
User Compatibility
MikroBus Compatible
Form Factor
24mm x 19mm
KW41Z Module
SoC
KW41Z512VHT4
kw41z.jpgVolansys KW41Z Module (for use with Modular Gateway) or Edge Devices
Kinetis® KW41Z
Protocols Supported
Zigbee, Thread, Bluetooth
User Compatibility
MikroBus Compatible
Form Factor
21mm x 16mm
Applications
Extremely low-power embedded systems
Portable health care devices
Wearable sports
Fitness devices
Computer keyboards and mice
Gaming controllers
Access control
Security systems
Smart energy
Home area networks
Medical Network
HVAC Control
Lighting control
Asset tracking
EDGE DEVICES
JN5169 , MKW2xD, MKW41Z
 Edge_Module_2-Compressed.pngVolansys Modular Edge Node Platform (Supports Same Radio Modules as Modular Gateway)
Protocols Supported
Thread, ZigBee and BLE
User Compatibility
MikroBus Compatible
Form Factor
74.98mm x 49.99mm
Applications
Smart Home
Buildings
Industries
What this Demo is All About
Video Link : 7307
  • Modular in design
  • MikroBus Compatible Modules
  • Supports ZigBee, Bluetooth, BLE, Thread, Wi-Fi (SigFox & Lora WAN coming soon)
  • Seamless Integration of your module in our gateway
  • Plug & use our modules to convert your products to solutions
     Volansys' NXP Specific Capabilities Presentation.
  • Volansys has created a KW2xD Thread ready module using NXPs' Kinetis KW22D512 Processor for adding thread support on Gateway.
  • The Above Demo reflects controlling of NXPs' Thread End Devices through Volansys Gateway using a mobile application.
  • The mobile application is developed on Android which can control the Thread End Devices sensors (LEDs, Accelerometer, Switch Press)
  • Built using the IAR compiler
  • Volansys IoT Gateway is a production ready modular design with effortless implementation and modification to manufacture your product and also provide a Connectivity solution to your product.
  • KW2xD is a Thread ready module with MikroBus Compatibility for easy integration to convert your products to  Thread ready solutions.
  • KW41Z is multi protocols supported module (Zigbee + Thread + BLE) with MikroBus Compatibility.
  • NXPs' NFC Tap Commissioning helps faster connectivity to the Gateway.
  • Volansys Gateway is also integrated with Amazon Alexa for controlling the IoT end devices using voice for effortless communication for the user.
Volansys Overview Presentation
Reach out to us
If you have any questions or comments, don't see exactly what you need, etc. please feel free to follow up with one of our IoT product managers directly, the IoT Solutions Center Follow Up Team, or the IoT Solutions Center Community: [email protected]
No ratings
Version history
Last update:
‎07-24-2019 09:03 AM
Updated by:
