S32G_LLCE_to_PFE_Demo Building(Chinese Version)
本文说明在S32G2 RDB2板上实现LLCE
to PFE Demo的搭建过程。本Demo目前包括:
 CANtoEth:CAN0发送,用硬件回环到
CAN1接收,然后通过PFE_EMAC1,
再通过RGMII接口发出。
再通过SGMII接口发出。
 EthtoCAN:PC通过PFE_EMAC1的
RGMII发出,接收到CAN1,再硬件
回环到CAN0
 CANtoCAN Logging to Eth: CAN0发
送,用硬件回环到CAN1接收,然后
通过PFE_EMAC1,再通过SGMII接
口发出,同时LLCE内部硬件把CAN1
再发送到CAN15_TX,再用硬件回环
到CAN14_RX
软件版本为
RTD3.0.0+LLCE1.0.3+PFE0.9.6/0.9.5。
%3CLINGO-SUB%20id%3D%22lingo-sub-1428875%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ES32G_LLCE_to_PFE_Demo%20Building(Chinese%20Version)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1428875%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%0A%3CP%3EThis%20article%20explains%20the%20implementation%20of%20LLCE%20on%20the%20S32G2%20RDB2%20board%3CBR%20%2F%3E%20to%20the%20construction%20process%20of%20PFE%20Demo.%20This%20Demo%20currently%20includes%3A%3CBR%20%2F%3E%20%EF%81%AC%20CANtoEth%3A%20CAN0%20sends%2C%20using%20hardware%20loopback%20to%3CBR%20%2F%3E%20CAN1%20receives%2C%20then%20passes%20through%20PFE_EMAC1%2C%3CBR%20%2F%3E%20Then%20send%20it%20through%20the%20RGMII%20interface.%3CBR%20%2F%3E%20%EF%81%AC%20CANtoEth%3A%20CAN0%20sends%2C%20using%20hardware%20loopback%20to%3CBR%20%2F%3E%20CAN1%20receives%2C%20then%20passes%20through%20PFE_EMAC1%2C%3CBR%20%2F%3E%20Then%20send%20it%20out%20through%20the%20SGMII%20interface.%3CBR%20%2F%3E%20%EF%81%AC%20EthtoCAN%3A%20PC%20via%20PFE_EMAC1%3CBR%20%2F%3E%20RGMII%20sends%20out%2C%20receives%20CAN1%2C%20and%20then%20loops%3CBR%20%2F%3E%20back%20to%20CAN0%3CBR%20%2F%3E%20by%20hardware%20%EF%81%AC%20CANtoCAN%20Logging%20to%20Eth%3A%20CAN0%3CBR%20%2F%3E%20sends%2C%20uses%20hardware%20loopback%20to%20CAN1%20to%20receive%2C%3CBR%20%2F%3E%20then%20passes%20through%20PFE_EMAC1%2C%20and%20then%20sends%20through%20the%20SGMII%20interface.%3CBR%20%2F%3E%20At%20the%20same%20time%2C%20LLCE%20internal%20hardware%20converts%20CAN1%3CBR%20%2F%3E%20Then%20send%20it%20to%20CAN15_TX%2C%20and%20then%20use%20hardware%20loopback%3CBR%20%2F%3E%20to%20CAN14_RX%3CBR%20%2F%3E%20Software%20version%20is%3CBR%20%2F%3E%20RTD3.0.0%2BLLCE1.0.3%2BPFE0.9.6%2F0.9.5.%3C%2FP%3E%0A%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1428875%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAutomotive%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎03-15-2022 07:02 PM
Updated by:
