Packet Tools Software gives you insight you normally only get from sophisticated test equipment.
Packet Tools uses the on-chip debug and trace capabilities of the QorIQ Processors to give you unprecedented insights into your system. This is the same insight you'll use to create real differentiation in your products.
This video gives you a VERY quick overview of the Packet Tools so you can get a great idea of what the software is all about.
