Patient Monitor Block Diagram
Description
The convergence of an aging population and breakthrough technological advances has created endless opportunities for automated medical devices.
These devices help ensure the future health of millions of people by providing advances in diabetes care, cardiac care, therapy adherence and general health and wellness applications. Regardless of the end use, developers of healthcare/medicals devices face similar challenges–the need to balance processing requirements with power consumption, a fast time-to-market, secure wireless connections and product longevity.
The application patient monitoring senses the vital signs of a patient and displays them. If any of the vital signs drops below a secure range the device will send an alert to the medical staff.
For the entry version of this application an i.MX 6 ULL applications processor is recommended for its low power consumption, touch screen driver integration and low cost.
Features
  • Checks patient vital signs and uploads them to the cloud
  • Quick alerts if the patient is in danger
  • Gathers the information of all the sensors in the human body
  • Secure wireless connections
  • Displays vital signs
Block Diagram
Products
Category Name 1:
MCU and MPU
Product URL 1
i.MX 6ULL Applications Processor | Single Arm® Cortex®-A7 @ 900 MHz | NXP
Product Description 1
The i.MX 6ULL applications processor includes an integrated power management module that reduces the complexity of an external power supply and simplifies power sequencing.
Product URL 2
i.MX 6Quad Applications Processors | Quad Arm® Cortex®-A9 | NXP
Product Description 2
The i.MX 6 series of applications processors combines scalable platforms with broad levels of integration and power-efficient processing capabilities particularly suited to multimedia applications.
Product URL 3
Arm® Cortex®-M0+|Kinetis® KM1x 50 MHz 32-bit MCUs | NXP
Product Description 3
The Kinetis® KM1x supports high-precision internal voltage reference with low temperature drift.
Category Name 2:
Power Management
Product URL 1
PMIC with 1A Li+ Linear Battery Charger | NXP
The PF1550 is a Power Management Integrated Circuit (PMIC) designed specifically for use with i.MX processors on low-power portable, smart wearable and Internet-of-Things (IoT) applications.
Product URL 2
14-Channel Configurable Power Management IC | NXP
The PF0100 SMARTMOS PMIC provides a highly programmable/configurable architecture, with fully integrated power devices and minimal external components.
Product URL 3
MC33772 | 6-Channel Li-ion Battery Cell Controller IC | NXP
The MC33772 is a Li-Ion battery cell controller IC designed for automotive and industrial applications such as HEV, EV, ESS, UPS systems.
Category Name 3:
Audio
Product URL 1
Ultra-Low-Power Audio Codec | NXP
The SGTL5000 is a low-power stereo codec is designed to provide a comprehensive audio solution for portable products that require line-in, mic-in, line-out, headphone-out and digital I/O.
Product URL 2
TDA8932B | NXP
The TDA8932B is a high efficiency class-D amplifier with low power dissipation.
Category Name 4:
Peripherals
Product URL 1
TJA1101 | 2nd generation PHY Transceiver | NXP
TJA1101 is a high-performance single port, IEEE 100BASE-T1 compliant Ethernet PHY Transceiver.
Product URL 2
 PCF85263A | NXP
The PCF85263A is a CMOS Real-Time Clock (RTC) and calendar optimized for low power consumption and with automatic switching to battery on main power loss.
Product URL 3
-50 to 50kPa, Differential and Gauge Pressure Sensor | NXP
On-chip, bipolar op amp circuitry and thin film resistor networks to provide a high output signal and temperature compensation
Documentation
Designing a Homemade Digital Output for Analog Voltage Output Sensor: https://www.nxp.com/docs/en/application-note/AN1586.pdf
Product Link
MCIMX6ULL-EVK: Evaluation kit for the i.MX 6ULL and 6ULZ Applications Processor MCIMX6ULL-EVK|i.MX6ULL Evaluation Kit | NXP
FRDM-PF1550EVM: PF1550 Evaluation Board for low power application processors FRDM-PF1550EVM | PF1550 Evaluation Board | NXP
SABRE for Automotive Infotainment Based on the i.MX 6 Series SABRE|Automotive-Infotainment|i.MX6 | NXP
KITPF0100EPEVBE: Evaluation Kit - MMPF0100, 14 Channel Configurable PMIC EVB- MMPF0100, 14 Channel Configurable PMIC | NXP
TWR-KM34Z50M: Kinetis M Series Tower System Module TWR-KM34Z50M|Tower System Board|Kinetis MCUs | NXP
KITSGTL5000EVBE: Evaluation Kit - SGTL5000, Low Power Stereo Codec SGTL5000, Low Power Stereo Codec EVB | NXP
FRDM33772BTPLEVB: Evaluation Board for MC33772 with Isolated Daisy Chain Communication FRDM33772BTPLEVB | MC33772 TPL EVB | NXP
OM13516UL: PCF85263B Evaluation board OM13516UL: PCF85263B Evaluation board | NXP
Labels (2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1112441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPatient%20Monitor%20Block%20Diagram%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CUL%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FPatient-Monitor-Block-Diagram%2Fta-p%2F1112441%23toc-hId-381472047%22%20target%3D%22_blank%22%3EDescription%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FPatient-Monitor-Block-Diagram%2Fta-p%2F1112441%23toc-hId--1425982416%22%20target%3D%22_blank%22%3EFeatures%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FPatient-Monitor-Block-Diagram%2Fta-p%2F1112441%23toc-hId-1061530417%22%20target%3D%22_blank%22%3EBlock%20Diagram%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FPatient-Monitor-Block-Diagram%2Fta-p%2F1112441%23toc-hId--745924046%22%20target%3D%22_blank%22%3EProducts%3C%2FA%3E%3C%2FLI%3E%3CLI%20style%3D%22list-style-type%3Adisc%3B%20margin-left%3A0px%3B%20margin-bottom%3A1px%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNXP-Designs-Knowledge-Base%2FPatient-Monitor-Block-Diagram%2Fta-p%2F1112441%23toc-hId-1741588787%22%20target%3D%22_blank%22%3EDocumentation%3C%2FA%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FP%3E%0A%3CH1%20id%3D%22toc-hId-381472047%22%20id%3D%22toc-hId-1297608879%22%3EDescription%3C%2FH1%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThe%20convergence%20of%20an%20aging%20population%20and%20breakthrough%20technological%20advances%20has%20created%20endless%20opportunities%20for%20automated%20medical%20devices.%3C%2FP%3E%0A%3CP%3EThese%20devices%20help%20ensure%20the%20future%20health%20of%20millions%20of%20people%20by%20providing%20advances%20in%20diabetes%20care%2C%20cardiac%20care%2C%20therapy%20adherence%20and%20general%20health%20and%20wellness%20applications.%20Regardless%20of%20the%20end%20use%2C%20developers%20of%20healthcare%2Fmedicals%20devices%20face%20similar%20challenges%E2%80%93the%20need%20to%20balance%20processing%20requirements%20with%20power%20consumption%2C%20a%20fast%20time-to-market%2C%20secure%20wireless%20connections%20and%20product%20longevity.%3C%2FP%3E%0A%3CP%20style%3D%22text-align%3A%20justify%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThe%20application%20patient%20monitoring%20senses%20the%20vital%20signs%20of%20a%20patient%20and%20displays%20them.%20If%20any%20of%20the%20vital%20signs%20drops%20below%20a%20secure%20range%20the%20device%20will%20send%20an%20alert%20to%20the%20medical%20staff.%3C%2FP%3E%0A%3CP%3EFor%20the%20entry%20version%20of%20this%20application%20an%20i.MX%206%20ULL%20applications%20processor%20is%20recommended%20for%20its%20low%20power%20consumption%2C%20touch%20screen%20driver%20integration%20and%20low%20cost.%3C%2FP%3E%0A%3CH1%20style%3D%22text-align%3A%20justify%3B%22%20id%3D%22toc-hId--1425982416%22%20id%3D%22toc-hId--509845584%22%3EFeatures%3C%2FH1%3E%0A%3CBR%20%2F%3E%0A%3CUL%3E%0A%3CLI%3EChecks%20patient%20vital%20signs%20and%20uploads%20them%20to%20the%20cloud%3C%2FLI%3E%0A%3CLI%3EQuick%20alerts%20if%20the%20patient%20is%20in%20danger%3C%2FLI%3E%0A%3CLI%3EGathers%20the%20information%20of%20all%20the%20sensors%20in%20the%20human%20body%3C%2FLI%3E%0A%3CLI%3ESecure%20wireless%20connections%3C%2FLI%3E%0A%3CLI%3EDisplays%20vital%20signs%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId-1061530417%22%20id%3D%22toc-hId-1977667249%22%3EBlock%20Diagram%3C%2FH1%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_8.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F94397i1BAD65F0C4D38369%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_8.png%22%20alt%3D%22pastedImage_8.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_8.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F89114i55838D8FE70DD1B6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId--745924046%22%20id%3D%22toc-hId-170212786%22%3EProducts%3C%2FH1%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22border%3A%200px%20none%20%233d3d3d%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ECategory%20Name%201%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20948px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EMCU%20and%20MPU%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20948px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi.mx-applications-processors%2Fi.mx-6-processors%2Fi.mx-6ull-single-core-processor-with-arm-cortex-a7-core%3Ai.MX6ULL%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi.mx-applications-processors%2Fi.mx-6-processors%2Fi.mx-6ull-single-core-processor-with-arm-cortex-a7-core%3Ai.MX6ULL%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%206ULL%20Applications%20Processor%20%7C%20Single%20Arm%C2%AE%20Cortex%C2%AE-A7%20%40%20900%20MHz%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20948px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EThe%20i.MX%206ULL%20applications%20processor%20includes%20an%20integrated%20power%20management%20module%20that%20reduces%20the%20complexity%20of%20an%20external%20power%20supply%20and%20simplifies%20power%20sequencing.%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%202%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20948px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi.mx-applications-processors%2Fi.mx-6-processors%2Fi.mx-6quad-processors-high-performance-3d-graphics-hd-video-arm-cortex-a9-core%3Ai.MX6Q%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-processors%2Fi.mx-applications-processors%2Fi.mx-6-processors%2Fi.mx-6quad-processors-high-performance-3d-graphics-hd-video-arm-cortex-a9-core%3Ai.MX6Q%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ei.MX%206Quad%20Applications%20Processors%20%7C%20Quad%20Arm%C2%AE%20Cortex%C2%AE-A9%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%202%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20948px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3EThe%20i.MX%206%20series%20of%20applications%20processors%20combines%20scalable%20platforms%20with%20broad%20levels%20of%20integration%20and%20power-efficient%20processing%20capabilities%20particularly%20suited%20to%20multimedia%20applications.%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%203%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20948px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-microcontrollers%2Fgeneral-purpose-mcus%2Fkm-series-cortex-m0-plus%2Fkinetis-km1x-50-mhz-mainstream-precision-metrology-microcontrollers-based-on-arm-cortex-m0-plus%3AKM1x%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fprocessors-and-microcontrollers%2Farm-microcontrollers%2Fgeneral-purpose-mcus%2Fkm-series-cortex-m0-plus%2Fkinetis-km1x-50-mhz-mainstream-precision-metrology-microcontrollers-based-on-arm-cortex-m0-plus%3AKM1x%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EArm%C2%AE%20Cortex%C2%AE-M0%2B%7CKinetis%C2%AE%20KM1x%2050%20MHz%2032-bit%20MCUs%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%203%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20948px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3EThe%20Kinetis%C2%AE%20KM1x%20supports%20high-precision%20internal%20voltage%20reference%20with%20low%20temperature%20drift.%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22border%3A%200px%20none%20%233d3d3d%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ECategory%20Name%202%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20947px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EPower%20Management%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20947px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics%2Fpmics-for-i.mx-applications-processors%2Fpmic-with-1a-li-plus-linear-battery-charger-for-low-power-processor-systems%3APF1550%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics%2Fpmics-for-i.mx-applications-processors%2Fpmic-with-1a-li-plus-linear-battery-charger-for-low-power-processor-systems%3APF1550%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPMIC%20with%201A%20Li%2B%20Linear%20Battery%20Charger%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20947px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EThe%20PF1550%20is%20a%20Power%20Management%20Integrated%20Circuit%20(PMIC)%20designed%20specifically%20for%20use%20with%20i.MX%20processors%20on%20low-power%20portable%2C%20smart%20wearable%20and%20Internet-of-Things%20(IoT)%20applications.%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%202%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20947px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics%2Fpmics-for-i.mx-applications-processors%2F14-channel-configurable-power-management-ic%3AMMPF0100%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fpmics%2Fpmics-for-i.mx-applications-processors%2F14-channel-configurable-power-management-ic%3AMMPF0100%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E14-Channel%20Configurable%20Power%20Management%20IC%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%202%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20947px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EThe%20PF0100%20SMARTMOS%20PMIC%20provides%20a%20highly%20programmable%2Fconfigurable%20architecture%2C%20with%20fully%20integrated%20power%20devices%20and%20minimal%20external%20components.%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%203%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20947px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fbattery-management%2Fbattery-cell-controllers%2F6-channel-li-ion-battery-cell-controller-ic%3AMC33772B%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fpower-management%2Fbattery-management%2Fbattery-cell-controllers%2F6-channel-li-ion-battery-cell-controller-ic%3AMC33772B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMC33772%20%7C%206-Channel%20Li-ion%20Battery%20Cell%20Controller%20IC%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%203%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20947px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EThe%20MC33772%20is%20a%20Li-Ion%20battery%20cell%20controller%20IC%20designed%20for%20automotive%20and%20industrial%20applications%20such%20as%20HEV%2C%20EV%2C%20ESS%2C%20UPS%20systems.%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22border%3A%200px%20none%20%233d3d3d%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ECategory%20Name%203%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20945px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EAudio%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20945px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Faudio%2Faudio-converters%2Fultra-low-power-audio-codec%3ASGTL5000%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Faudio%2Faudio-converters%2Fultra-low-power-audio-codec%3ASGTL5000%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EUltra-Low-Power%20Audio%20Codec%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20945px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EThe%20SGTL5000%20is%20a%20low-power%20stereo%20codec%20is%20designed%20to%20provide%20a%20comprehensive%20audio%20solution%20for%20portable%20products%20that%20require%20line-in%2C%20mic-in%2C%20line-out%2C%20headphone-out%20and%20digital%20I%2FO.%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%202%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20945px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Faudio%2Faudio-amplifiers%2Fhome-audio-amplifiers%2Fclass-d-audio-amplifier%3ATDA8932B%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Faudio%2Faudio-amplifiers%2Fhome-audio-amplifiers%2Fclass-d-audio-amplifier%3ATDA8932B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETDA8932B%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%202%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20945px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EThe%20TDA8932B%20is%20a%20high%20efficiency%20class-D%20amplifier%20with%20low%20power%20dissipation.%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20style%3D%22border%3A%200px%20none%20%233d3d3d%3B%22%3E%0A%3CTBODY%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22border%3A%201pt%20solid%20windowtext%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ECategory%20Name%204%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-left%3A%20none%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20942px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EPeripherals%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20942px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fethernet-%2Fautomotive-ethernet-phy-transceivers%2F2nd-generation-ethernet-phy-transceivers-ieee-100base-t1-compliant%3ATJA1101%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Finterfaces%2Fethernet-%2Fautomotive-ethernet-phy-transceivers%2F2nd-generation-ethernet-phy-transceivers-ieee-100base-t1-compliant%3ATJA1101%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETJA1101%20%7C%202nd%20generation%20PHY%20Transceiver%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%201%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20942px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3ETJA1101%20is%20a%20high-performance%20single%20port%2C%20IEEE%20100BASE-T1%20compliant%20Ethernet%20PHY%20Transceiver.%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%202%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20942px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fsignal-chain%2Freal-time-clocks%2Frtcs-with-ic-bus%2Ftiny-real-time-clock-calendar-with-alarm-function-battery-switch-over-time-stamp-input-and-ic-bus%3APCF85263A%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fsignal-chain%2Freal-time-clocks%2Frtcs-with-ic-bus%2Ftiny-real-time-clock-calendar-with-alarm-function-battery-switch-over-time-stamp-input-and-ic-bus%3APCF85263A%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPCF85263A%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2075px%3B%22%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2075px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%202%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20942px%3B%20height%3A%2075px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EThe%20PCF85263A%20is%20a%20CMOS%20Real-Time%20Clock%20(RTC)%20and%20calendar%20optimized%20for%20low%20power%20consumption%20and%20with%20automatic%20switching%20to%20battery%20on%20main%20power%20loss.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20URL%203%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20942px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Fpressure-sensors%2Fvacuum-sensors-50-to-115-kpa%2F-50-to-50kpa-differential-and-gauge-pressure-sensor%3AMPXx5050%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsensors%2Fpressure-sensors%2Fvacuum-sensors-50-to-115-kpa%2F-50-to-50kpa-differential-and-gauge-pressure-sensor%3AMPXx5050%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E-50%20to%2050kPa%2C%20Differential%20and%20Gauge%20Pressure%20Sensor%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%20style%3D%22height%3A%2025px%3B%22%3E%0A%3CTD%20style%3D%22border-right%3A%201pt%20solid%20windowtext%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-left%3A%201pt%20solid%20windowtext%3B%20border-image%3A%20initial%3B%20border-top%3A%20none%3B%20background%3A%20%23f2f2f2%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20155px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EProduct%20Description%203%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3CTD%20style%3D%22border-top%3A%20none%3B%20border-left%3A%20none%3B%20border-bottom%3A%201pt%20solid%20windowtext%3B%20border-right%3A%201pt%20solid%20windowtext%3B%20padding%3A%200in%205.4pt%3B%20width%3A%20942px%3B%20height%3A%2025px%3B%22%3E%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3EOn-chip%2C%20bipolar%20op%20amp%20circuitry%20and%20thin%20film%20resistor%20networks%20to%20provide%20a%20high%20output%20signal%20and%20temperature%20compensation%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%0A%3CBR%20%2F%3E%0A%3CH1%20id%3D%22toc-hId-1741588787%22%20id%3D%22toc-hId--1637241677%22%3EDocumentation%3C%2FH1%3E%0A%3CP%3EDesigning%20a%20Homemade%20Digital%20Output%20for%20Analog%20Voltage%20Output%20Sensor%3A%26nbsp%3B%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1586.pdf%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1586.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN1586.pdf%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CTABLE%20class%3D%22j-table%20jiveBorder%22%20style%3D%22border%3A%201px%20solid%20%23c6c6c6%3B%22%20width%3D%22100%25%22%3E%0A%3CTHEAD%3E%0A%3CTR%20style%3D%22background-color%3A%20%2352cc8f%3B%22%3E%0A%3CTH%20style%3D%22width%3A%2046.8453%25%3B%22%3EProduct%3C%2FTH%3E%0A%3CTH%20style%3D%22width%3A%2051.2532%25%3B%22%3ELink%3C%2FTH%3E%0A%3C%2FTR%3E%0A%3C%2FTHEAD%3E%0A%3CTBODY%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2046.8453%25%3B%22%3EMCIMX6ULL-EVK%3A%20Evaluation%20kit%20for%20the%20i.MX%206ULL%20and%206ULZ%20Applications%20Processor%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2051.2532%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi.mx-evaluation-and-development-boards%2Fevaluation-kit-for-the-i.mx-6ull-and-6ulz-applications-processor%3AMCIMX6ULL-EVK%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi.mx-evaluation-and-development-boards%2Fevaluation-kit-for-the-i.mx-6ull-and-6ulz-applications-processor%3AMCIMX6ULL-EVK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EMCIMX6ULL-EVK%7Ci.MX6ULL%20Evaluation%20Kit%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2046.8453%25%3B%22%3EFRDM-PF1550EVM%3A%20PF1550%20Evaluation%20Board%20for%20low%20power%20application%20processors%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2051.2532%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Fpf1550-evaluation-board-for-low-power-application-processors%3AFRDM-PF1550EVM%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Fpf1550-evaluation-board-for-low-power-application-processors%3AFRDM-PF1550EVM%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFRDM-PF1550EVM%20%7C%20PF1550%20Evaluation%20Board%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2046.8453%25%3B%22%3ESABRE%20for%20Automotive%20Infotainment%20Based%20on%20the%20i.MX%206%20Series%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2051.2532%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi.mx-evaluation-and-development-boards%2Fsabre-for-automotive-infotainment-based-on-the-i.mx-6-series%3ARDIMX6SABREAUTO%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fi.mx-evaluation-and-development-boards%2Fsabre-for-automotive-infotainment-based-on-the-i.mx-6-series%3ARDIMX6SABREAUTO%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESABRE%7CAutomotive-Infotainment%7Ci.MX6%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2046.8453%25%3B%22%3EKITPF0100EPEVBE%3A%20Evaluation%20Kit%20-%20MMPF0100%2C%2014%20Channel%20Configurable%20PMIC%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2051.2532%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Fevaluation-kit-mmpf0100-14-channel-configurable-pmic%3AKITPF0100EPEVBE%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Fevaluation-kit-mmpf0100-14-channel-configurable-pmic%3AKITPF0100EPEVBE%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EEVB-%20MMPF0100%2C%2014%20Channel%20Configurable%20PMIC%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2046.8453%25%3B%22%3ETWR-KM34Z50M%3A%20Kinetis%20M%20Series%20Tower%20System%20Module%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2051.2532%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Ftower-development-boards%2Fmcu-and-processor-modules%2Fkinetis-modules%2Fkinetis-m-series-tower-system-module%3ATWR-KM34Z50M%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Ftower-development-boards%2Fmcu-and-processor-modules%2Fkinetis-modules%2Fkinetis-m-series-tower-system-module%3ATWR-KM34Z50M%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ETWR-KM34Z50M%7CTower%20System%20Board%7CKinetis%20MCUs%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2046.8453%25%3B%22%3EKITSGTL5000EVBE%3A%20Evaluation%20Kit%20-%20SGTL5000%2C%20Low%20Power%20Stereo%20Codec%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2051.2532%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Fevaluation-kit-sgtl5000-low-power-stereo-codec%3AKITSGTL5000EVBE%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Fevaluation-kit-sgtl5000-low-power-stereo-codec%3AKITSGTL5000EVBE%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESGTL5000%2C%20Low%20Power%20Stereo%20Codec%20EVB%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2046.8453%25%3B%22%3EFRDM33772BTPLEVB%3A%20Evaluation%20Board%20for%20MC33772%20with%20Isolated%20Daisy%20Chain%20Communication%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2051.2532%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Fevaluation-board-for-mc33772-with-isolated-daisy-chain-communication%3AFRDM33772BTPLEVB%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdevelopment-boards%2Fanalog-toolbox%2Fevaluation-board-for-mc33772-with-isolated-daisy-chain-communication%3AFRDM33772BTPLEVB%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFRDM33772BTPLEVB%20%7C%20MC33772%20TPL%20EVB%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3CTR%3E%0A%3CTD%20style%3D%22width%3A%2046.8453%25%3B%22%3EOM13516UL%3A%20PCF85263B%20Evaluation%20board%3C%2FTD%3E%0A%3CTD%20style%3D%22width%3A%2051.2532%25%3B%22%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fsignal-chain%2Freal-time-clocks%2Frtcs-with-ic-bus%2Fom13516ul-pcf85263b-evaluation-board%3AOM13516UL%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fperipherals-and-logic%2Fsignal-chain%2Freal-time-clocks%2Frtcs-with-ic-bus%2Fom13516ul-pcf85263b-evaluation-board%3AOM13516UL%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EOM13516UL%3A%20PCF85263B%20Evaluation%20board%20%7C%20NXP%3C%2FA%3E%26nbsp%3B%3C%2FTD%3E%0A%3C%2FTR%3E%0A%3C%2FTBODY%3E%0A%3C%2FTABLE%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1112441%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EBlock%20Diagrams%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EIndustrial%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎10-20-2020 09:26 AM
Updated by:
