Kinetis V Series Ebike Powered by Kinetis Motor Suite
Demo
Go to your local bicycle store and you will see just how popular Ebike are becoming. To help power this revolution further Kinetis Motor Suite will enable your motor control solution quickly. KMS is used to tune and control the motor with FOC torque control, with the startup control modified to uses the hall effect inputs to improve start-up power.
Features:
- A sensorless FOC Brushless DC (BLDC) motor control application with torque control, using a Kinetis V Series KV3x ARM Cortex-M4 MCU and the Kinetis Motor Suite solution.
- KMS supports the development of sensored and sensorless velocity control, and sensored position control applications for PMSM and BLDC motors
____________________________________________________________________________________________________________________________
Featured NXP Products:
Product | Link |
Kinetis® KV3x-100–120 MHz, Advanced 3ph FOC / Sensorless Motor Control MCUs based on Arm® Cortex®-M4 | Arm® Cortex®-M4|Kinetis® KV3x Real-time Control MCUs | NXP |
Kinetis® KV3x Family Tower® System Module | https://www.nxp.com/design/development-boards/tower-development-boards/mcu-and-processor-modules/kin... |
Low-Voltage, 3-Phase Motor Control Tower® System Module | https://www.nxp.com/design/development-boards/tower-development-boards/peripheral-modules/low-voltag... |
Freedom Development Platform for Kinetis® KV3x Family MCUs | FRDM-KV31F|Freedom Development Platform|Kinetis® MCU | NXP |
NXP® Freedom Development Platform for Low-Voltage, 3-Phase PMSM Motor Control | https://www.nxp.com/design/development-boards/freedom-development-boards/mcu-boards/nxp-freedom-deve... |
Online Training:
C63
