read single block
read single block
richardharendar
how to read single block with the ISO 15693 ?
have you an example for the following tag NFC SL2 ICS50 ?
isaacavila
Hello Richard,
There is an example for ISO 15693 tags in the NFC Reader Library for PN5180 front end: PN5180|NXP
In this example, you can find the phalI15693_ReadSingleBlock API function that is used to read single block from tag.
/* Read single block */
                        status = phalI15693_ReadSingleBlock(&salI15693,
                                                            PHAL_I15693_OPTION_OFF,
                                                            bBlock,
                                                            &pRxbuffer,
                                                            &bDataLength);
You can try to give a look to this example!
Hope this helps!
Isaac
