pn7220 antenna current
zhangkai
Hello, could you advise how to configure the NFC antenna current for PN7220 via libnfc-nxp-rfExt.conf or other configuration files? Our tests show the antenna current is too high and needs to be reduced.
Tomas_Parizek
Hello @zhangkai ,
If you only need to reduce/limit the current, you can do it in the same way as described here: https://community.nxp.com/t5/NFC-Knowledge-Base/PN7642-Basic-RF-power-limitation-using-DPC/ta-p/2187...
TOma
Tomas_Parizek
Hello @zhangkai ,
TOma
KaiLi
Hello @zhangkai
Recommends to enable DPC , but before enable DPC,which needs to be  calibrated.
%3CLINGO-SUB%20id%3D%22lingo-sub-2392081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Epn7220%20antenna%20current%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20could%20you%20advise%20how%20to%20configure%20the%20NFC%20antenna%20current%20for%20PN7220%20via%20libnfc-nxp-rfExt.conf%20or%20other%20configuration%20files%3F%20Our%20tests%20show%20the%20antenna%20current%20is%20too%20high%20and%20needs%20to%20be%20reduced.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2392380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20pn7220%20antenna%20current%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262699%22%20target%3D%22_blank%22%3E%40zhangkai%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ERecommends%20to%20enable%20DPC%20%2C%20but%20before%20enable%20DPC%2Cwhich%20needs%20to%20be%26nbsp%3B%20calibrated.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2393043%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20pn7220%20antenna%20current%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2393043%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262699%22%20target%3D%22_blank%22%3E%40zhangkai%3C%2FA%3E%26nbsp%3B%2C%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIf%20you%20only%20need%20to%20reduce%2Flimit%20the%20current%2C%20you%20can%20do%20it%20in%20the%20same%20way%20as%20described%20here%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FPN7642-Basic-RF-power-limitation-using-DPC%2Fta-p%2F2187514%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC-Knowledge-Base%2FPN7642-Basic-RF-power-limitation-using-DPC%2Fta-p%2F2187514%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3ETOma%3C%2FP%3E%3C%2FLINGO-BODY%3E
