mfrc631 chips break down during normal operation
1,903件の閲覧回数
zbigniewkalisia
Hello
Many mfrc631 chips on my antenna board break down (burn out) during normal operation (Mifare card reading) without external stimuli. Is it possible that with properly designed hardware the software could damage the chip? Where should I look firstly for problems : hardware / software ? What could be the reason?
I noticed that powerdown signal is very sensitive and when stay not connected it quickly leads to damage.
Zbigniew Kalisiak
タグ(1)
3 返答(返信)
1,771件の閲覧回数
vicentegomez
Did you check that there is not a solder short under the devic?.
Did you perform an ICT test?
1,771件の閲覧回数
zbigniewkalisia
I very detailed checked PCB soldering and there is no shorts. I use other older MIFARE chips without any problem and I've never burn it on PCB.
1,771件の閲覧回数
vicentegomez
What happend if you put a new device on the PCB?
