how to disable random id feature on SN100T?
2,300 次查看
jeremyliu
I want to get the static 7byte UID from SN100T as a card emulation, but I get a 4byte random id every time, is there a solution to solve this?  thanks a lot.
4 回复数
2,260 次查看
jeremyliu
ok, get it, but I hope get more infomation about random id,  RID is enabled on SL3,  I can't change SL3 to SL2 or lower level,  but I think it can be enabled/disabled if it just a feature, I hava same issue on other NFC IC,  can you give me some suggestion? thanks a lot
2,265 次查看
jeremyliu
is there any ideas?
2,262 次查看
danielchen
HI @jeremyliu
SN100T is not a mass market product.  You need to contact with NXP local FAE or representative for support.
https://www.nxp.com/support/sample-and-buy/distributor-network:DISTRIBUTORS
2,256 次查看
jeremyliu
