how to calculate the UHF tag's forward sensitivity by hfss or cst
3,315件の閲覧回数
Louis666
Hi, Sirs:
i am now simulate Alien's antenna 9662 with chip ucode 9  ,and when i read the datasheet of ucode9,so many impedance make me so confused。
we assemble the chip with single-slit, so the right impedance should be 10-j191? is that correct?
you can see the inlay in the attachment.
タグ(2)
8 返答(返信)
3,294件の閲覧回数
EduardoZamora
Hello @Louis666,
Hope you are doing well.
In case of single-slit antenna assembly, antenna shall be matched to that impedance (10-j191Ω).
Eduardo.
3,282件の閲覧回数
Louis666
ok ,thankyou verymuch.
we simulate 9662 with HFSS,and we get the antenna's Gian and Impedance。
and by this formula
POTF = 𝐺 *𝑝 * (1 − |(Zchip-Zant∗)/(Zchip+Zant)|^2)/𝑃𝑡ℎ
𝑝 is the polarization mismatch factor(In most cases should be 1 ),𝑃𝑡ℎ is the chip sensitivity,POTF is tag's forward sensitivity.
we calculate the UHF tag's forward sensitivity。however ,sometimes we find there may be inconsistencies between simulated values and measured values, and in many cases, the two may differ by 5-8dB,is that normal ?or the formula needs to be revised ?
タグ(1)
3,263件の閲覧回数
EduardoZamora
UCODE 9 has a self-adjust feature, which is an automatic mechanism that adjusts the chip sensitivity to a maximum in the operated environment for automated tag performance optimization. For more information, please refer to UCODE 9 Data Sheet, Section 9.6.2.
Eduardo.
3,250件の閲覧回数
Louis666
Hi, EduardoZamora:
YES,we know that when test it's performance on tagformance,we disabled self-adjust feature before ,and we just compare the data after turning off self-tuning and simulation,they also can't match well.
Do you know what's the reason?
Maybe our calculation method is incorrect. How about you calculate the UHF tag's forward sensitivity ?can you provide how you calculate the tag's POTF?
thanks!
3,221件の閲覧回数
EduardoZamora
My apologies, this information is not available. Some considerations for the sensitivity measurements are a 2.5 dBi gain antenna and center capacitor of self-adjust.
Eduardo.
3,206件の閲覧回数
Louis666
Hi,EduardoZamora:
can you share something information to calculate the UHF tag's forward sensitivity by simulation?
THANKS!
3,137件の閲覧回数
EduardoZamora
Our support is limited to the information that is available in the published documentation, and this information is not available.
I truly apologize for the inconvenience.
Eduardo.
3,240件の閲覧回数
Louis666
sorry to forget add the attachment.
