What happens when the CommitTransaction command is executed
1,623件の閲覧回数
mschraufstetter
What happens to a BackupDataFile at DESFire when the CommitTransaction command is executed?
A BackupDataFile is twice as large as a normal file. Will the data be copied when executing the command?
タグ(1)
1,548件の閲覧回数
Jonathan_Iglesias
Dear Markus Schraufstetter,
Hope you are doing great, as you may know the information about DESFire ev1 and Ev2 is secured under NDA ( Non Disclosure Agreement) this means that all the information, tools and support should be delivered using secured communication channels and only with customers with active NDA.  the information you require is in the full datasheet available in Docstore, section 6.7.1.2.
if you do not have NDA please contact your closest distributor.
Have a great day !
Jonathan
