TagXplorer NFC System Requirements for Linux and macOS
1,341件の閲覧回数
jvacanti
Can someone share the runtime requirements for using the TagXplorer NFC Tag reader on a Linux or Mac system? I created a support ticket through NXP and all they told me was it requires "Java 8". The errors the JavaFX version gives with the Oracle Java 8 version says the JavaFX is using a format in JavaFX 9. Was this software built using the Oracle Java 9 SDK with a bundled JavaFX 9? When I use Java 9 + JavaFX 9 I get other errors.
I linked to this question: https://community.nxp.com/t5/NFC/TagXplorer-and-Ubuntu-18-04LTS/td-p/1160733 who is having similar issues but has not found a resolution.
Here are the errors I get right now:
Oracle Java 8 (with JavaFX bundled)
JAVA_HOME=./jdk1.8.0_291/ ./jdk1.8.0_291/bin/java -Dsun.security.smartcardio.library=/usr/lib/x86_64-linux-gnu/libpcsclite.so.1 -jar TagXplorer-v1.2.jar
May 19, 2021 10:55:57 AM javafx.fxml.FXMLLoader$ValueElement processValue
WARNING: Loading FXML document with JavaFX API of version 9.0.1 by JavaFX runtime of version 8.0.291
May 19, 2021 10:55:57 AM com.sun.javafx.css.parser.CSSParser declaration
WARNING: CSS Error parsing jar:file:/home/jared/dev/smartcards/lib/sw488312/TagXplorer-v1.2.jar!/css/Launch_Screen_Style.css: expected series of <size> while parsing 'box-shadow' at [28,13]
WARNING: CSS Error parsing jar:file:/home/jared/dev/smartcards/lib/sw488312/TagXplorer-v1.2.jar!/css/Launch_Screen_Style.css: expected series of <size> while parsing 'box-shadow' at [33,13]
WARNING: CSS Error parsing jar:file:/home/jared/dev/smartcards/lib/sw488312/TagXplorer-v1.2.jar!/css/Launch_Screen_Style.css: Expected '<font-weight>' while parsing '-fx-font-weight' at [42,18]
WARNING: CSS Error parsing jar:file:/home/jared/dev/smartcards/lib/sw488312/TagXplorer-v1.2.jar!/css/Launch_Screen_Style.css: expected series of <size> while parsing 'box-shadow' at [64,13]
WARNING: CSS Error parsing jar:file:/home/jared/dev/smartcards/lib/sw488312/TagXplorer-v1.2.jar!/css/Launch_Screen_Style.css: expected series of <size> while parsing 'box-shadow' at [189,13]
Oracle Java 9 (with JavaFX bundled)
JAVA_HOME=./jdk-9.0.1/ ./jdk-9.0.1/bin/java -Dsun.security.smartcardio.library=/usr/lib/x86_64-linux-gnu/libpcsclite.so.1 -jar TagXplorer-v1.2.jar
May 19, 2021 10:30:36 AM javafx.scene.control.Control loadSkinClass
SEVERE: Failed to load skin 'com.sun.javafx.scene.control.skin.ProgressBarSkin' for control ProgressBar[id=splashProgressBar, styleClass=progress-bar progress-bar]
java.lang.ClassNotFoundException: com.sun.javafx.scene.control.skin.ProgressBarSkin
	at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:582)
	at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:496)
	at java.base/java.lang.Class.forName0(Native Method)
	at java.base/java.lang.Class.forName(Class.java:375)
	at javafx.controls/javafx.scene.control.Control.loadClass(Control.java:124)
	at javafx.controls/javafx.scene.control.Control.loadSkinClass(Control.java:720)
	at javafx.controls/javafx.scene.control.Control$5.invalidated(Control.java:680)
	at javafx.base/javafx.beans.property.StringPropertyBase.markInvalid(StringPropertyBase.java:110)
	at javafx.base/javafx.beans.property.StringPropertyBase.set(StringPropertyBase.java:145)
	at javafx.graphics/javafx.css.StyleableStringProperty.set(StyleableStringProperty.java:83)
	at javafx.controls/javafx.scene.control.Control$5.set(Control.java:672)
	at javafx.graphics/javafx.css.StyleableStringProperty.applyStyle(StyleableStringProperty.java:69)
	at javafx.graphics/javafx.css.StyleableStringProperty.applyStyle(StyleableStringProperty.java:45)
	at javafx.graphics/javafx.scene.CssStyleHelper.transitionToState(CssStyleHelper.java:772)
	at javafx.graphics/javafx.scene.Node.doProcessCSS(Node.java:9631)
	at javafx.graphics/javafx.scene.Node.access$900(Node.java:398)
	at javafx.graphics/javafx.scene.Node$1.doProcessCSS(Node.java:471)
	at javafx.graphics/com.sun.javafx.scene.NodeHelper.processCSSImpl(NodeHelper.java:206)
	at javafx.graphics/com.sun.javafx.scene.ParentHelper.superProcessCSSImpl(ParentHelper.java:95)
	at javafx.graphics/com.sun.javafx.scene.ParentHelper.superProcessCSS(ParentHelper.java:65)
	at javafx.graphics/javafx.scene.Parent.doProcessCSS(Parent.java:1388)
	at javafx.graphics/javafx.scene.Parent.access$400(Parent.java:81)
	at javafx.graphics/javafx.scene.Parent$1.doProcessCSS(Parent.java:127)
	at javafx.graphics/com.sun.javafx.scene.ParentHelper.processCSSImpl(ParentHelper.java:100)
	at javafx.controls/com.sun.javafx.scene.control.ControlHelper.superProcessCSSImpl(ControlHelper.java:63)
	at javafx.controls/com.sun.javafx.scene.control.ControlHelper.superProcessCSS(ControlHelper.java:55)
	at javafx.controls/javafx.scene.control.Control.doProcessCSS(Control.java:886)
	at javafx.controls/javafx.scene.control.Control.access$000(Control.java:83)
	at javafx.controls/javafx.scene.control.Control$1.doProcessCSS(Control.java:89)
	at javafx.controls/com.sun.javafx.scene.control.ControlHelper.processCSSImpl(ControlHelper.java:67)
	at javafx.graphics/com.sun.javafx.scene.NodeHelper.processCSS(NodeHelper.java:147)
	at javafx.graphics/javafx.scene.Parent.doProcessCSS(Parent.java:1419)
	at javafx.graphics/javafx.scene.Node.processCSS(Node.java:9513)
	at javafx.graphics/javafx.scene.Scene.doCSSPass(Scene.java:583)
	at javafx.graphics/javafx.scene.Scene.preferredSize(Scene.java:1770)
	at javafx.graphics/javafx.scene.Scene$2.preferredSize(Scene.java:394)
	at javafx.graphics/com.sun.javafx.scene.SceneHelper.preferredSize(SceneHelper.java:66)
	at javafx.graphics/javafx.stage.Window$12.invalidated(Window.java:1098)
	at javafx.base/javafx.beans.property.BooleanPropertyBase.markInvalid(BooleanPropertyBase.java:110)
	at javafx.base/javafx.beans.property.BooleanPropertyBase.set(BooleanPropertyBase.java:145)
	at javafx.graphics/javafx.stage.Window.setShowing(Window.java:1186)
	at javafx.graphics/javafx.stage.Window.show(Window.java:1201)
	at javafx.graphics/javafx.stage.Stage.show(Stage.java:276)
	at com.nxp.tagxplorer.Main.start(Main.java:66)
	at javafx.graphics/com.sun.javafx.application.LauncherImpl.lambda$launchApplication1$9(LauncherImpl.java:919)
	at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runAndWait$11(PlatformImpl.java:449)
	at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runLater$9(PlatformImpl.java:418)
	at java.base/java.security.AccessController.doPrivileged(Native Method)
	at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runLater$10(PlatformImpl.java:417)
	at javafx.graphics/com.sun.glass.ui.InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:96)
	at javafx.graphics/com.sun.glass.ui.gtk.GtkApplication._runLoop(Native Method)
	at javafx.graphics/com.sun.glass.ui.gtk.GtkApplication.lambda$runLoop$11(GtkApplication.java:277)
	at java.base/java.lang.Thread.run(Thread.java:844)
	at javafx.controls/javafx.scene.control.Control.doProcessCSS(Control.java:900)
May 19, 2021 10:30:38 AM javafx.css.CssParser declaration
May 19, 2021 10:30:41 AM javafx.css.CssParser declaration
WARNING: CSS Error parsing jar:file:/home/jared/dev/smartcards/lib/sw488312/TagXplorer-v1.2.jar!/css/alertdailog.css: expected series of <size> while parsing 'box-shadow' at [28,13]
WARNING: CSS Error parsing jar:file:/home/jared/dev/smartcards/lib/sw488312/TagXplorer-v1.2.jar!/css/alertdailog.css: expected series of <size> while parsing 'box-shadow' at [34,13]
OpenJDK 11 (11.0.9.hs-adpt) + external JavaFX 11 LTS (https://gluonhq.com/products/javafx/)
java -Dsun.security.smartcardio.library=/usr/lib/x86_64-linux-gnu/libpcsclite.so.1 --module-path /home/jared/dev/smartcards/lib/sw488312/javafx-sdk-11.0.2/lib/ --add-modules javafx.controls,javafx.fxml -jar TagXplorer-v1.2.jar
May 19, 2021 10:59:28 AM javafx.scene.control.Control loadSkinClass
	at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:581)
	at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
	at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
	at java.base/java.lang.Class.forName(Class.java:398)
	at javafx.graphics/javafx.scene.CssStyleHelper.transitionToState(CssStyleHelper.java:787)
	at javafx.graphics/javafx.scene.Node.doProcessCSS(Node.java:9647)
	at javafx.graphics/com.sun.javafx.scene.NodeHelper.processCSSImpl(NodeHelper.java:192)
	at javafx.graphics/com.sun.javafx.scene.ParentHelper.superProcessCSSImpl(ParentHelper.java:93)
	at javafx.graphics/com.sun.javafx.scene.ParentHelper.superProcessCSS(ParentHelper.java:63)
	at javafx.graphics/javafx.scene.Parent.doProcessCSS(Parent.java:1366)
	at javafx.graphics/javafx.scene.Parent.access$400(Parent.java:79)
	at javafx.graphics/javafx.scene.Parent$1.doProcessCSS(Parent.java:125)
	at javafx.graphics/com.sun.javafx.scene.ParentHelper.processCSSImpl(ParentHelper.java:98)
	at javafx.graphics/com.sun.javafx.scene.NodeHelper.processCSS(NodeHelper.java:145)
	at javafx.graphics/javafx.scene.Parent.doProcessCSS(Parent.java:1397)
	at javafx.graphics/javafx.scene.Node.processCSS(Node.java:9529)
	at javafx.graphics/javafx.scene.Scene.doCSSPass(Scene.java:569)
	at javafx.graphics/javafx.scene.Scene.preferredSize(Scene.java:1745)
	at javafx.graphics/javafx.scene.Scene$2.preferredSize(Scene.java:393)
	at javafx.graphics/javafx.stage.Window$12.invalidated(Window.java:1086)
	at javafx.graphics/javafx.stage.Window.setShowing(Window.java:1174)
	at javafx.graphics/javafx.stage.Window.show(Window.java:1189)
	at javafx.graphics/javafx.stage.Stage.show(Stage.java:273)
	at javafx.graphics/com.sun.javafx.application.LauncherImpl.lambda$launchApplication1$9(LauncherImpl.java:846)
	at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runAndWait$12(PlatformImpl.java:455)
	at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runLater$10(PlatformImpl.java:428)
	at javafx.graphics/com.sun.javafx.application.PlatformImpl.lambda$runLater$11(PlatformImpl.java:427)
	at java.base/java.lang.Thread.run(Thread.java:834)
May 19, 2021 10:59:30 AM javafx.css.CssParser declaration
May 19, 2021 10:59:34 AM javafx.css.CssParser declaration
So all three combinations give errors. Is the TagXplorer app still supported? I am using a supported reader on Ubuntu (Identiv 3700) and can't connect.
Thanks in advance for any help.
0 返答(返信)
