Suitable NFC Writer for NTAG424
cchan101
Hi, I'm looking for a suitable NFC writer that can write NTAG 424 DNA standard of chip and is able to change the masterkey for the chip as well. Any suggestions? I saw from other posts that people mentioned using the TagXplorer software, but not sure which reader/writer to use together with TagXplorer. I'm also looking for more scalable solutions that can be used to write large amounts of chips without taking a lot of time per chip. Thank you very much for the help.
KaiLi
Hello @cchan101
Thanks for contacting us and interested in the NXP products.
Please check the attachment, your questions could be answered here.
To update this case, you may reply by email.
To provide confidential information or attachments, you may add that online.
Please login to our NXP technical support portal:
https://support.nxp.com/s/case/5002p00002s4R4yAAE
The portal allows access to the full details of the case, including the previous communication.
Thank you for your interest in NXP Semiconductor products and for the opportunity to serve you.
Kelly
Technical Support
NXP Semiconductor
