Seamless first-time tap with NTAG 424 DNA – optimization tips?
sander1117
Hi all,
We’re currently deploying NTAG 424 DNA tags in a passive NFC application using Secure Dynamic Messaging (SDM). The tags are configured to generate a dynamic URL that includes picc_data and cmac, which our backend verifies on each tap.
Functionally, everything works – but in practice, we’re experiencing inconsistent tap performance, especially with mobile phones:
  • Some users need to tap multiple times or find a very specific angle or distance.
  • The first-tap experience is not always reliable, which causes frustration.
  • We want to improve stability and make the experience as seamless as possible across a range of phone models (iOS & Android).
Setup details:
  • Tag: NTAG 424 DNA
  • Mode: SDM with dynamic URL (mirroring picc_data, cmac)
  • Form factor: PVC card (120 x 140 mm), matte laminated
  • Antenna: Embedded loop antenna 76x46
  • Reader device: Smartphones only – no dedicated NFC hardware
What we’d like to understand:
  1. Are there antenna design recommendations (size, coil layout, substrate) to improve mobile phone readability?
  2. Would adding ferrite backing help?
  3. How can we check for antenna/chip mismatch or improper tuning to 13.56 MHz?
  4. Are there any known best practices for improving passive NFC usability with smartphones in real-world deployments?
We are open to hardware tweaks, tuning advice, or layout adjustments – anything that can help improve first-try tap reliability without switching to active/NFC emulation.
Thanks in advance for any insights or resources you can share!
EduardoZamora
Hello @sander1117
I will recommend you taking a look at the NTAG Antenna Design Guide. This document provides all necessary information to design antennas for NXP NTAG ICs that are compatible with NFC compliant R/W devices. Within this Antenna Deign Guide you will also find a document that describes the design of 13.56 MHz Smartcard Stickers with Ferrite, but this is oriented to contactless function design independently of the material it is sticked to.
Also, you could use the NFC Antenna Tool as a reference for the antenna parameters and optional matching.
Eduardo.
%3CLINGO-SUB%20id%3D%22lingo-sub-2142920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESeamless%20first-time%20tap%20with%20NTAG%20424%20DNA%20%E2%80%93%20optimization%20tips%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2142920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20all%2C%3C%2FP%3E%3CP%3EWe%E2%80%99re%20currently%20deploying%20%3CSTRONG%3ENTAG%20424%20DNA%3C%2FSTRONG%3E%20tags%20in%20a%20passive%20NFC%20application%20using%20%3CSTRONG%3ESecure%20Dynamic%20Messaging%20(SDM)%3C%2FSTRONG%3E.%20The%20tags%20are%20configured%20to%20generate%20a%20dynamic%20URL%20that%20includes%20picc_data%20and%20cmac%2C%20which%20our%20backend%20verifies%20on%20each%20tap.%3C%2FP%3E%3CP%3EFunctionally%2C%20everything%20works%20%E2%80%93%20but%20in%20practice%2C%20we%E2%80%99re%20experiencing%20%3CSTRONG%3Einconsistent%20tap%20performance%3C%2FSTRONG%3E%2C%20especially%20with%20mobile%20phones%3A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3ESome%20users%20need%20to%20tap%20multiple%20times%20or%20find%20a%20very%20specific%20angle%20or%20distance.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EThe%20first-tap%20experience%20is%20not%20always%20reliable%2C%20which%20causes%20frustration.%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EWe%20want%20to%20improve%20stability%20and%20make%20the%20experience%20as%20seamless%20as%20possible%20across%20a%20range%20of%20phone%20models%20(iOS%20%26amp%3B%20Android).%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CHR%20%2F%3E%3CH3%20id%3D%22toc-hId-1972815611%22%20id%3D%22toc-hId-1999767762%22%3ESetup%20details%3A%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3ETag%3A%3C%2FSTRONG%3E%20NTAG%20424%20DNA%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EMode%3A%3C%2FSTRONG%3E%20SDM%20with%20dynamic%20URL%20(mirroring%20picc_data%2C%20cmac)%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EForm%20factor%3A%3C%2FSTRONG%3E%20PVC%20card%20(120%20x%20140%20mm)%2C%20matte%20laminated%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EAntenna%3A%3C%2FSTRONG%3E%20Embedded%20loop%20antenna%2076x46%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EReader%20device%3A%3C%2FSTRONG%3E%20Smartphones%20only%20%E2%80%93%20no%20dedicated%20NFC%20hardware%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CHR%20%2F%3E%3CH3%20id%3D%22toc-hId-165361148%22%20id%3D%22toc-hId-192313299%22%3EWhat%20we%E2%80%99d%20like%20to%20understand%3A%3C%2FH3%3E%3COL%3E%3CLI%3E%3CP%3EAre%20there%20antenna%20design%20recommendations%20(size%2C%20coil%20layout%2C%20substrate)%20to%20improve%20mobile%20phone%20readability%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EWould%20adding%20%3CSTRONG%3Eferrite%20backing%3C%2FSTRONG%3E%26nbsp%3Bhelp%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EHow%20can%20we%20check%20for%20%3CSTRONG%3Eantenna%2Fchip%20mismatch%3C%2FSTRONG%3E%20or%20improper%20tuning%20to%2013.56%20MHz%3F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EAre%20there%20any%20known%20%3CSTRONG%3Ebest%20practices%20for%20improving%20passive%20NFC%20usability%20with%20smartphones%3C%2FSTRONG%3E%20in%20real-world%20deployments%3F%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3EWe%20are%20open%20to%20hardware%20tweaks%2C%20tuning%20advice%2C%20or%20layout%20adjustments%20%E2%80%93%20anything%20that%20can%20help%20improve%20first-try%20tap%20reliability%20without%20switching%20to%20active%2FNFC%20emulation.%3C%2FP%3E%3CP%3EThanks%20in%20advance%20for%20any%20insights%20or%20resources%20you%20can%20share!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2143856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Seamless%20first-time%20tap%20with%20NTAG%20424%20DNA%20%E2%80%93%20optimization%20tips%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143856%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253240%22%20target%3D%22_blank%22%3E%40sander1117%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EI%20will%20recommend%20you%20taking%20a%20look%20at%20the%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN11276.zip%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ENTAG%20Antenna%20Design%20Guide%3C%2FA%3E.%20This%20document%20provides%20all%20necessary%20information%20to%20design%20antennas%20for%20NXP%20NTAG%20ICs%20that%20are%20compatible%20with%20NFC%20compliant%20R%2FW%20devices.%20Within%20this%20Antenna%20Deign%20Guide%20you%20will%20also%20find%20a%20document%20that%20describes%20the%20design%20of%2013.56%20MHz%20Smartcard%20Stickers%20with%20Ferrite%2C%20but%20this%20is%20oriented%20to%20contactless%20function%20design%20independently%20of%20the%20material%20it%20is%20sticked%20to.%3C%2FP%3E%0A%3CP%3EAlso%2C%20you%20could%20use%20the%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FNFC%2Fbd-p%2Fnfc%22%20target%3D%22_blank%22%3ENFC%20Antenna%20Tool%3C%2FA%3E%20as%20a%20reference%20for%20the%20antenna%20parameters%20and%20optional%20matching.%3C%2FP%3E%0A%3CP%3ERegards%2C%3CBR%20%2F%3EEduardo.%3C%2FP%3E%3C%2FLINGO-BODY%3E
