ST25R3916 - Mifare libraries
3,721件の閲覧回数
arnodegroot
We have a project based on the ST25R3916.
In order to access the memory of Mifare classic cards, authentication is required.
On NXP reader ICs, this functionality is already inside the chip.
Is Mifare functionality a pure software based functionality and can we use a Mifare library in the ST25R3916 based project? Or, does it require additional hardware next to the ST25R3916?
If so, how to obtain this library?
Arno
3,512件の閲覧回数
Jonathan_Iglesias
Hi ,
as you may know the usage and migrations to non NXP devices is not under our scope.  you can migrate the library to any device you want but we do not ensure the nfcreader library working on other device this depends on you and how you migrate it, you can use as reference this post :
https://community.nxp.com/docs/DOC-340908
Have a great day !
Br
Jonathan
