SL3S4011 change config datasheet error?
Lemer
In SL3S4011 datasheet at paragraph 10.3 there is the change config command exemple. Is the a bit map error for the exemple "E.g., sending 0000 0000 0000 0000 1001 XOR RN16 will activate the EPC Read Protect and PSF bit" ? The bit map does not match...
What should we send for the handle value? I seek for the handle word in the datasheet and I did not find any explanation...
Mich
2996467262
The problem I encountered is that the I2C interrupt cannot be turned on using RF, and every time the card reader returns the value of the Configuration word is 0x0240
