Read time stamp abnormal, Using PN7160 to read/write NTAG I²C Plus 2K tag problem
yanpuja_yh
I'm using PN7160 to read/write NTAG I²C Plus 2K tag. And using example of NXP revised program,
I found
"NxpNci_HostTransceive(NCIReadTS, sizeof(NCIReadTS), Answer, sizeof(Answer), &AnswerSize)"
return answer[1] = 0x02, from example, the correct value is  answer[1] = 0x03.
Who can tell me what's the meaning is 0x02 or 0x03?
Erklei
It is defined in  NFC Controller Interface (NCI) Specification document
yanpuja_yh
Hi Erklei
  Thank you very much for your answer.
Could you tell me where can I get "NCI Specification"?
