Programming PN7642 with MCUXpresso
901 次查看
MPEngineering
Hey there,
i got two problems using the #PN7642 (Dev Kit) with MCUXpresso (v24.12.148, SDK version 2.12.5)
First one is, that i´m not able to use kGPIO_I2CM_SDA and kGPIO_I2CM_SCL Pins as Output pins. Trying to set them high results in 0,5 V level.
I tried SPIM pins as Output and this was no problem.
Second one is, that i cannot see the Register values using Peripheral+ view. When I stop the Controller in debug mode, all Registers are red. Only Timer Component shows me some values. What could cause this?
Oliver
5 回复数
869 次查看
MPEngineering
Well, i want to know the recent register values which i wrote to the controller.
In my understanding I use Peripherals+ view to show the recent values.
So stopping the Controller in debug mode should show me these values, but i only see the red highlighted Registers without values.
What could be the problem?
829 次查看
KaiLi
Hello @MPEngineering
This should be related to the IDE. You can use an intermediate variable (reg_value) for debugging. That is, you can read the value of the peripheral register and assign it to reg_value, then add reg_value to the debugging window. At this time, you can see the value of the register. It is recommended that you try this.
893 次查看
KaiLi
You should configure the register PCRM_PADOUT (0xBB) to set SDA/SCL as general GPIO, and then these two pins can be configured to have a high or low output.
891 次查看
MPEngineering
Hey KaiLi,
got it.
And what about the Register View? See the photo attached.
876 次查看
KaiLi
It should be as the below:
%3CLINGO-SUB%20id%3D%22lingo-sub-2135746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%BF%E7%94%A8%20MCUXpresso%20%E5%AF%B9%20PN7642%20%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E4%BB%AC%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%20MCUXpresso%EF%BC%88v24.12.148%EF%BC%89%E4%B8%8A%E4%BD%BF%E7%94%A8%20%23PN7642%EF%BC%88%E5%BC%80%E5%8F%91%E5%A5%97%E4%BB%B6%EF%BC%89%E6%97%B6%E9%81%87%E5%88%B0%E4%B8%A4%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%81SDK%20%E7%89%88%E6%9C%AC%202.12.5)%3C%2FP%3E%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E5%B0%86%3CSPAN%3EkGPIO_I2CM_SDA%3C%2FSPAN%3E%E5%92%8C%3CSPAN%3EkGPIO_I2CM_SCL%3C%2FSPAN%3E%E5%BC%95%E8%84%9A%E7%94%A8%E4%BD%9C%E8%BE%93%E5%87%BA%E5%BC%95%E8%84%9A%E3%80%82%E5%B0%9D%E8%AF%95%E5%B0%86%E5%AE%83%E4%BB%AC%E8%AE%BE%E7%BD%AE%E4%B8%BA%E9%AB%98%E7%94%B5%E5%B9%B3%EF%BC%8C%E7%BB%93%E6%9E%9C%E6%98%AF%200.5%20V%20%E7%94%B5%E5%B9%B3%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%B0%86%20SPIM%20%E5%BC%95%E8%84%9A%E4%BD%9C%E4%B8%BA%E8%BE%93%E5%87%BA%EF%BC%8C%E7%BB%93%E6%9E%9C%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%AC%AC%E4%BA%8C%E4%B8%AA%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20Peripheral%2B%20%E8%A7%86%E5%9B%BE%E6%9F%A5%E7%9C%8B%E5%AF%84%E5%AD%98%E5%99%A8%E5%80%BC%E3%80%82%E5%BD%93%E6%88%91%E5%9C%A8%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%81%9C%E6%AD%A2%E6%8E%A7%E5%88%B6%E5%99%A8%E6%97%B6%EF%BC%8C%E6%89%80%E6%9C%89%E5%AF%84%E5%AD%98%E5%99%A8%E9%83%BD%E6%98%AF%E7%BA%A2%E8%89%B2%E7%9A%84%E3%80%82%E5%8F%AA%E6%9C%89%E8%AE%A1%E6%97%B6%E5%99%A8%E5%85%83%E5%99%A8%E4%BB%B6%E5%90%91%E6%88%91%E6%98%BE%E7%A4%BA%E4%B8%80%E4%BA%9B%E5%80%BC%E3%80%82%E4%BB%80%E4%B9%88%E5%8E%9F%E5%9B%A0%E4%BC%9A%E5%AF%BC%E8%87%B4%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E5%A5%A5%E5%88%A9%E5%BC%97%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136951%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Programming%20PN7642%20with%20MCUXpresso%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136951%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248495%22%20target%3D%22_blank%22%3E%40MPEngineering%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E5%BA%94%E8%AF%A5%E4%B8%8E%20IDE%20%E6%9C%89%E5%85%B3%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%B8%AD%E9%97%B4%E5%8F%98%E9%87%8F%20(reg_value)%20%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%E3%80%82%E4%B9%9F%E5%B0%B1%E6%98%AF%E8%AF%B4%EF%BC%8C%E5%8F%AF%E4%BB%A5%E8%AF%BB%E5%8F%96%E5%A4%96%E8%AE%BE%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%80%BC%E5%B9%B6%E5%B0%86%E5%85%B6%E8%B5%8B%E5%80%BC%E7%BB%99%20reg_value%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%20reg_value%20%E6%B7%BB%E5%8A%A0%E5%88%B0%E8%B0%83%E8%AF%95%E7%AA%97%E5%8F%A3%E3%80%82%E6%AD%A4%E6%97%B6%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E5%80%BC%E3%80%82%E5%BB%BA%E8%AE%AE%E6%82%A8%E5%B0%9D%E8%AF%95%E4%B8%80%E4%B8%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Programming%20PN7642%20with%20MCUXpresso%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%9C%80%E8%BF%91%E5%86%99%E5%85%A5%E6%8E%A7%E5%88%B6%E5%99%A8%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E5%80%BC%E3%80%82%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%88%91%E7%9A%84%E7%90%86%E8%A7%A3%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%20Peripherals%2B%20%E8%A7%86%E5%9B%BE%E6%9D%A5%E6%98%BE%E7%A4%BA%E6%9C%80%E8%BF%91%E7%9A%84%E6%95%B0%E5%80%BC%E3%80%82%3CBR%20%2F%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%9C%A8%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%81%9C%E6%AD%A2%E6%8E%A7%E5%88%B6%E5%99%A8%EF%BC%8C%E5%BA%94%E8%AF%A5%E8%83%BD%E7%9C%8B%E5%88%B0%E8%BF%99%E4%BA%9B%E5%80%BC%EF%BC%8C%E4%BD%86%E6%88%91%E5%8F%AA%E7%9C%8B%E5%88%B0%E7%BA%A2%E8%89%B2%E7%AA%81%E5%87%BA%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%B2%A1%E6%9C%89%E7%9C%8B%E5%88%B0%E5%80%BC%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Programming%20PN7642%20with%20MCUXpresso%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136540%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248495%22%20target%3D%22_blank%22%3E%40MPEngineering%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%BA%94%E8%AF%A5%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22KaiLi_0-1752838727806.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KaiLi_0-1752838727806.png%22%20style%3D%22width%3A%20372px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348268i2F2F4E344039A077%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22KaiLi_0-1752838727806.png%22%20alt%3D%22KaiLi_0-1752838727806.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2135897%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Programming%20PN7642%20with%20MCUXpresso%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135897%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%98%BF%EF%BC%8CKaiLi%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%98%8E%E7%99%BD%E4%BA%86%20%3CBR%20%2F%3E%E9%82%A3%E4%B9%88%E6%B3%A8%E5%86%8C%E8%A7%86%E5%9B%BE%E5%8F%88%E6%98%AF%E4%BB%80%E4%B9%88%E5%91%A2%EF%BC%9F%E8%AF%B7%E7%9C%8B%E9%99%84%E5%9B%BE%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2135848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Programming%20PN7642%20with%20MCUXpresso%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135848%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248495%22%20target%3D%22_blank%22%3E%40MPEngineering%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%BA%94%E9%85%8D%E7%BD%AE%E5%AF%84%E5%AD%98%E5%99%A8%20PCRM_PADOUT%20(0xBB)%EF%BC%8C%E5%B0%86%20SDA%2FSCL%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E9%80%9A%E7%94%A8%20GPIO%EF%BC%8C%E7%84%B6%E5%90%8E%E5%B0%86%E8%BF%99%E4%B8%A4%E4%B8%AA%E5%BC%95%E8%84%9A%E9%85%8D%E7%BD%AE%E4%B8%BA%E9%AB%98%E7%94%B5%E5%B9%B3%E6%88%96%E4%BD%8E%E7%94%B5%E5%B9%B3%E8%BE%93%E5%87%BA%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
