POS machine in Android with SAM card interface with EMVCO contactless L1 and L2.
2,510 次查看
engineer_embedd
We are developing a POS machine in Android with SAM card interface. We would like to certify this with EMVCO contactless L1 and L2. Present design including PN7150 (NFC controller with integrated firmware P5DF081 MIFARE SAM AV2 or AV2.6 (SAM card IC) and Android™support. Is EMVCO certification is possible with this..? Kindly support our requirement asap.
标记 (3)
1 回复
2,211 次查看
Jonathan_Iglesias
Dear Divya George,
as you may know the information related to SAM is secured under NDA  ( Non Disclosure Agreement) this means that all the information, tools and support, should be delivered using secured communication channels and only to customers with active NDA, to get the information you require please contact your closest certified distributor, Distributor Network | NXP
Have a great day !
Jonathan
