PN7642 Module FCC ID
gredpath
We have designed a NFC module based around PN7642, is there an application note on meeting the FCC requirements to get it listed as a module?
EduardoZamora
Hello @gredpath
Hope you are doing well.
My apologies, there is no specific documentation about FCC-compliance. I would recommend you confirm that you have followed the guidelines included in PN76 family antenna design guide, which describes the NFC antenna design and tuning, DPC functionality and layout recommendations; also, please take a look at the PN7642 design-in recommendations.
Additionally, I could also recommend following the NFC Antenna Design training series as it describes key aspects for the antenna, debugging, test and qualification, and EMC related design.
Eduardo.
scroggyg
Thanks Eduardo, I have followed the guidelines and the unit has passed testing. FCC has particular requirements, such as a mandatory screen can, which is used on the pagoda reference design, which I had used as a starting point. Beyond that it is mainly paperwork!
