PN7462 booting issue
2,165件の閲覧回数
sanath_rai
Hello ,
I am working on PNEV7462C development board.
I am using MCUXpresso IDE and i have run all the example codes on the board which worked perfectly.
But after i tried to flash the code in to EEPROM using GUI Flash tool and came back to normal debug mode i am unable to run any application it is getting stuck at  function phFlashBoot_PreCheck()  at line
PH_USER_ASSERT(gpkphCfg_EE_Ctrl_VerInfo->major == PH_FLASHBOOT_SUPPORTED_EEPROM_VERISON_MAJOR);
What might be the issue?
Anything wrong with the FLASH ?
Sanath Rai
ラベル(2)
2 返答(返信)
1,898件の閲覧回数
sanath_rai
I had used GUI Flash tool to erase and program the Flash.
It may have erased the primary boot loader .Can i flash the boot loader again if yes what is the tool use to do that?
Sanath Rai
1,898件の閲覧回数
jimmychan
Please refer to this document : https://www.nxp.com/docs/en/user-guide/UM10948.pdf
FYI. PN7462 updating EEPROM on linux
If you want to program the example to the board, please refer to this:
https://community.nxp.com/message/1032919
