PN7462 FW and SW examples full (NDA) version incomplete?
已解决
跳至解决方案
4,117 次查看
jarojuda
I downloaded Sw368319 - PN7462AU FW And SW Examples Full Version - V05_12_00 (1.9) from docstore.
The package PN7462AU-FW_v05.12.00_Extended.zip seems corrupted.
 No example involving MIFARE DESFIRE compiles. The other examples compile well.
There are unresolved dependencies from phalMfdf.h (the log attached).
I noticed that files from the phalMfdf component differs from that I have downloaded in Sw375617 - NFC Reader Library V05.12.00 Including MIFARE DESFire, MIFARE Plus And ICODE DNA Modules (1.7).
I replaced the MIFARE DESFIRE component in the PN7462 Extended by that from  Sw375617 and now all examples compiles.
Did any of you have a similar problem?
标签 (2)
标记 (1)
1 解答
3,624 次查看
Kan_Li
Hi Jaroslaw,
There is a updated version available on docstore, would you please try it?
Hope that helps,
Kan
在原帖中查看解决方案
2 回复数
3,497 次查看
thiago_machado
Hi. I just downloaded the PDF file containing all the files, but it's for a passwork in order to open the PDF file. How can I get this password?
3,625 次查看
Kan_Li
Hi Jaroslaw,
Hope that helps,
Kan
