PN7462 - Accessing XXX_AUX with API
2,059件の閲覧回数
stefanmueller
Dear Ladies and Gentlemen,
according to datasheet CLK_AUX, IO_AUX and INT_AUX can be configured as normal GPIOs.
How can I do that with delivered API?
Do I have to write my own API?
Thank you in advance.
Best Regards
Stefan
タグ(2)
2 返答(返信)
1,700件の閲覧回数
HASS_123
can you share me the github link of PN7462 API or any document of complete API ?
1,849件の閲覧回数
weidong_sun
Hello Mueller ,
    See http://www.nxp.com/documents/user_manual/UM10858.pdf , in the document, you will get detailed information on how to configure PN7462's registers.
    See http://www.nxp.com/documents/user_manual/UM10913.pdf ,in the document, you will get detailed information on how to use APIs we provided.
So if you want to design your own API, you will have to do following steps:
(1)Knowing how to configure register through UM10858.pdf
(2)Knowing how to use PN7462's API to write/read registers.
(3)Using PN7462's API to write your own API.
Hope above information can be helpful for you!
Weidong
