PN7462 APDU
PN7462 APDU
emmanuel_john
Is it possible to use APDU’s by USB host when no card is inserted in the card reader?
Jonathan_Iglesias
Dear Emmanuel John
Hope you are doing great,  if you try to send a command while there is no card connected or activated you will get error "40h" which means card deactivated so in order to send commands you need to have an activated card.
Jonathan
