PN7150 error during configuration
3,882件の閲覧回数
i_kamal
We have many devices operating correctly.
For some reason, at some point in time, the device fails to initialize (no mater how much we reboot or reset it).
When I send this configuration:
NCI >> 20 02 a3 13 a0 0d 06 04 35 90 01 f4 01 a0 0d 06 06 44 01 90 03 00 a0 0d 06 06 30 b0 01 10 00 a0 0d 06 06 42 02 00 ff ff a0 0d 03 06 3f 04 a0 0d 06 20 42 88 00 ff ff a0 0d 04 22 44 22 00 a0 0d 06 22 2d 50 34 0c 00 a0 0d 06 32 42 f8 00 ff ff a0 0d 06 34 2d 24 37 0c 00 a0 0d 06 34 33 86 80 00 70 a0 0d 04 34 44 22 00 a0 0d 06 42 2d 15 45 0d 00 a0 0d 04 46 44 22 00 a0 0d 06 46 2d 05 59 0e 00 a0 0d 06 44 42 88 00 ff ff a0 0d 06 56 2d 05 9f 0c 00 a0 0d 06 54 42 88 00 ff ff a0 0d 06 0a 33 80 86 00 70
I get this response:
NCI << 40 02 08 09 03 a0 0d a0 0d a0 0d
which is causing the problem, as the library expects 40 02 00 00.
I have no idea what does the "08 09" in my case means, and how can fix this?
Is there any tool to interpret those messages? any manual i can look into?
Any hints on this urgent matter would be much appreciated.
4 返答(返信)
2,084件の閲覧回数
vil
Hi there:
I got success response when I mixed a00d (RF_TRANSITION_CFG)  and a01d.
                                       20 02 36 05 a0 0d 06 06  42 00 02 ff ff a0 0d 03 | .6..... B.......
                                       00 40 01 a0 0d 06 06 03  00 6d 00 20 a0 0d 06 06 |.@...... .m. ....
                                       30 c8 00 64 00 a0 1d 11  55 33 14 17 00 aa 85 00 |0..d.... U3......
                                       80 55 2a 04 00 63 00 00  00                      |.U*..c.. .
                                       40 02 02 00 00
  1. PN7150 UM10936 section 10.3 says, avoid mixing RF transition params 0xa00d with other params. However, I got it mixed by mistake.  My question is, If it got mixed, will it surely corrupt?
  2. Can an example be given to surely corrupt the eeprom? I want to corrupt and see whether PN7150B0HN/C11006 can send the CORE_RESET_NTF with 0xe6 reason code.
  3. Can the eeprom corruption in PN7150B0HN/C11006 fully recoverable?
  4. What is the test to know a pn7150 chip is surely corrupted?
  5. What is the test to know a pn7150 chip is surely NOT corrupted?
    Appreciate your help to understand the above.  Thank you.
3,794件の閲覧回数
IvanRuiz
The issue relates to internal EEPROM memory corruption. This issue is described in UM10936 chapter 10.3, and must be avoided following recommendations depicted there. Unfortunately, there is no way to recover from this issue on the corrupted device.
FYI, in "NCI << 40 02 08 09 03 a0 0d a0 0d a0 0d" frame:
- "40 02" indicates the frame type (response to CORE_SET_CONFIG command)
- "08" indicates the payload size
- "09" is the status byte (STATUS_INVALID_PARAM)
Hope this helps.
BR,
Ivan.
3,794件の閲覧回数
i_kamal
Thank you Ivan.
So, just to confirm: the chips having this issue should simply be discarded?
Hmm... no way to rewrite the EEPROM?
3,794件の閲覧回数
IvanRuiz
Please accept my apologies, since the memory was corrupted, there is no way to recover from this.
BR,
Ivan.
%3CLINGO-SUB%20id%3D%22lingo-sub-957203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%A7%8B%E6%88%90%E4%B8%AD%E3%81%AEPN7150%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-957203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E5%A4%9A%E6%95%B0%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E3%80%81%E3%81%82%E3%82%8B%E6%99%82%E7%82%B9%E3%81%A7%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%20(%E4%BD%95%E5%BA%A6%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E3%82%82%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%A8%3A%3C%2FP%3E%3CP%3ENCI%20%26gt%3B%26gt%3B%2020%2002%20a3%2013%20a0%200d%2006%2004%2035%2090%2001%20f4%2001%20a0%200d%2006%2006%2044%2001%2090%2003%2000%20a0%200d%2006%2006%2030%20b0%2001%2010%2000%20a0%200d%2006%2006%2042%2002%2000%20ff%20ff%20a0%200d%2003%2006%203f%2004%20a0%200d%2006%2020%2042%2088%2000%20ff%20ff%20a0%200d%2004%2022%2044%2022%2000%20a0%200d%2006%2022%202d%2050%2034%200c%2000%20a0%200d%2006%2032%2042%20f8%2000%20ff%20ff%20a0%200d%2006%2034%202d%2024%2037%200c%2000%20a0%200d%2006%2034%2033%2086%2080%2000%2070%20a0%200d%2004%2034%2044%2022%2000%20a0%200d%2006%2042%202d%2015%2045%200d%2000%20a0%200d%2004%2046%2044%2022%2000%20a0%200d%2006%2046%202d%2005%2059%200e%2000%20a0%200d%2006%2044%2042%2088%2000%20ff%20ff%20a0%200d%2006%2056%202d%2005%209f%200c%2000%20a0%200d%2006%2054%2042%2088%2000%20ff%20ff%20a0%200d%2006%200a%2033%2080%2086%2000%2070%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E8%BF%94%E7%AD%94%E3%81%8C%E8%BF%94%E3%81%A3%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3ENCI%20%26lt%3B%26lt%3B%2040%2002%20%3CSTRONG%3E08%2009%3C%2FSTRONG%3E%2003%20a0%200d%20a0%200d%20a0%200d%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%2040%2002%20%3CSTRONG%3E00%2000%3C%2FSTRONG%3E%E3%82%92%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%80%8C08%2009%E3%80%8D%E3%81%8C%E4%BD%95%E3%82%92%E6%84%8F%E5%91%B3%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E5%85%A8%E3%81%8F%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%93%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E8%A7%A3%E9%87%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%E5%8F%82%E7%85%A7%E3%81%A7%E3%81%8D%E3%82%8B%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E7%B7%8A%E6%80%A5%E3%81%AE%E3%83%9E%E3%82%BF%E3%83%BC%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%83%92%E3%83%B3%E3%83%88%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E5%A4%A7%E5%A4%89%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-957203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ENFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%83%BB%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2196630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7150%20error%20during%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2196630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%84%E3%81%82%EF%BC%9A%3C%2FP%3E%3CP%3Ea00d%20(RF_TRANSITION_CFG)%20%E3%81%A8%20a01d%20%E3%82%92%E6%B7%B7%E5%9C%A8%E3%81%95%E3%81%9B%E3%82%8B%E3%81%A8%E6%88%90%E5%8A%9F%E5%BF%9C%E7%AD%94%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E20%2002%2036%20%3CSTRONG%3E%3CEM%3E05%3C%2FEM%3E%20a0%200d%3C%2FSTRONG%3E%2006%2006%2042%2000%2002%20ff%20ff%20%3CSTRONG%3Ea0%200d%3C%2FSTRONG%3E%2003%20%7C%20.6.....%20B.......%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E00%2040%2001%20%3CSTRONG%3Ea0%200d%3C%2FSTRONG%3E%2006%2006%2003%2000%206d%2000%2020%20%3CSTRONG%3Ea0%200d%3C%2FSTRONG%3E%2006%2006%20%7C.%40.......m%E3%80%82%20....%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E30%20c8%2000%2064%2000%20%3CSTRONG%3Ea0%201d%3C%2FSTRONG%3E%2011%2055%2033%2014%2017%2000%20aa%2085%2000%20%7C0..d....%20U3......%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E80%2055%202a%2004%2000%2063%2000%2000%2000%20%7C.U*..c..%20.%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E40%2002%2002%2000%2000%3CBR%20%2F%3E%20%3D%3D%3D%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3COL%3E%3CLI%3E%3CSPAN%3EPN7150%20UM10936%20%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%2010.3%20%E3%81%AB%E3%81%AF%E3%80%81RF%20%E9%81%B7%E7%A7%BB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%200xa00d%20%E3%82%92%E4%BB%96%E3%81%AE%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%A8%E6%B7%B7%E5%9C%A8%E3%81%95%E3%81%9B%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%AB%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E9%96%93%E9%81%95%E3%81%88%E3%81%A6%E6%B7%B7%E3%81%9C%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AF%E3%80%81%E6%B7%B7%E3%81%96%E3%81%A3%E3%81%9F%E3%82%89%E5%BF%85%E3%81%9A%E8%85%90%E6%95%97%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E7%A2%BA%E5%AE%9F%E3%81%AB%20EEPROM%20%E3%81%8C%E7%A0%B4%E6%90%8D%E3%81%99%E3%82%8B%E4%BE%8B%E3%82%92%E6%8C%99%E3%81%92%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3FPN7150B0HN%2FC11006%20%E3%81%8C%200xe6%20%E7%90%86%E7%94%B1%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%20CORE_RESET_NTF%20%E3%82%92%E9%80%81%E4%BF%A1CAN%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A0%B4%E5%A3%8A%E3%81%97%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3EPN7150B0HN%2FC11006%20%E3%81%AE%20EEPROM%20%E7%A0%B4%E6%90%8D%E3%81%AF%E5%AE%8C%E5%85%A8%E3%81%AB%E5%9B%9E%E5%BE%A9%E5%8F%AF%E8%83%BDCAN%EF%BC%9F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3Epn7150%20%E3%83%81%E3%83%83%E3%83%97%E3%81%8C%E7%A2%BA%E5%AE%9F%E3%81%AB%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3Epn7150%20%E3%83%81%E3%83%83%E3%83%97%E3%81%8C%E7%A2%BA%E5%AE%9F%E3%81%AB%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B8%8A%E8%A8%98%E3%82%92%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-957206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7150%20error%20during%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-957206%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%8C%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E5%9B%9E%E5%BE%A9%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3EBR%E3%80%81%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E3%82%A4%E3%83%AF%E3%83%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-957205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7150%20error%20during%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-957205%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%82%A4%E3%83%B4%E3%82%A1%E3%83%B3%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3ESO%E3%80%81%E7%A2%BA%E8%AA%8D%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E3%81%82%E3%82%8B%E3%83%81%E3%83%83%E3%83%97%E3%81%AF%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E5%BB%83%E6%A3%84%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%E3%81%86%E3%83%BC%E3%82%93...EEPROM%E3%82%92%E6%9B%B8%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-957204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7150%20error%20during%20configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-957204%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E5%86%85%E9%83%A8%20EEPROM%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%81%AE%E7%A0%B4%E6%90%8D%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20class%3D%22%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttps%253A%252F%252Fwww.nxp.com%252Fdocs%252Fen%252Fuser-guide%252FUM10936.pdf%22%20style%3D%22color%3A%20%233d9ce7%3B%20border%3A%200px%3B%20font-weight%3A%20inherit%3B%20text-decoration%3A%20none%3B%20padding%3A%200px%20calc(12px%20%2B%200.35ex)%200px%200px%3B%22%20target%3D%22_blank%22%3EUM10936%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FA%3E10.3%20%E7%AB%A0%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%9D%E3%81%93%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%9F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%9B%9E%E5%BE%A9%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%E3%80%8CNCI%20%26lt%3B%26lt%3B%2040%2002%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%20style%3D%22border%3A%200px%3B%20font-weight%3A%20bold%3B%22%3E08%2009%3C%2FSTRONG%3E%3CSPAN%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E03%20a0%200d%20a0%200d%20a0%200d%22%20%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%3A%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E-%20%E3%80%8C40%2002%E3%80%8D%E3%81%AF%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%82%BF%E3%82%A4%E3%83%97%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88CORE_SET_CONFIG%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%B8%E3%81%AE%E5%BF%9C%E7%AD%94%EF%BC%89%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E-%20%E3%80%8C08%E3%80%8D%E3%81%AF%E3%83%9A%E3%82%A4%E3%83%AD%E3%83%BC%E3%83%89%E3%82%B5%E3%82%A4%E3%82%BA%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E-%20%E3%80%8C09%E3%80%8D%E3%81%AF%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%83%90%E3%82%A4%E3%83%88%EF%BC%88%20%3CSPAN%20class%3D%22%22%20style%3D%22border%3A%200px%3B%20font-weight%3A%20inherit%3B%22%3ESTATUS_INVALID_PARAM%3C%2FSPAN%3E%20%EF%BC%89%E3%81%A7%E3%81%99%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3EBR%E3%80%81%3C%2FP%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%22%3E%E3%82%A4%E3%83%AF%E3%83%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
