PN7150 android S porting Guidelines
sunhy
通过查阅文档:AN11690
https://www.nxp.com.cn/docs/en/application-note/AN11690.pdf
我们发现pn7150没有Android S的porting说明,请问有Android S的porting说明文档吗?
danielchen
Hi @sunhy
For PN7150, we can support android version up to android 11.  for later newer android versions, please use PN7160. so we don't have a guideline for android S version for PN7150.
please refer to pn7160 product page for more details
https://www.nxp.com/products/rfid-nfc/nfc-hf/nfc-readers/nfc-plug-and-play-controller-with-integrate...
danielchen
Hi @sunhy
sunhy
Can I use the hardware of the pn7150 and then refer to the porting guide of the 7160?
sumankumar
Dear Team, @sunhy @danielchen
We are at the same situation as Sunhy.
We have considerable number of units using PN7150 deployed at customer field.
We want to integrate PN7150 for Android 13.
@sunhy Are you using the below github link as starting point of integration?
https://github.com/NXPNFCLinux/nxpnfc_android_r
@danielchen Any suggestions on how to proceed with integration?
Should we directly take PN7160 Android 13 patches for Kernel, HAL but replace the .conf files from Android 11 to Android 13 for PN7150?
Should we take PN7150 Android-11 files and replace it for Android 13 codebase and solve any errors/warnings?
Which is the best and correct approach?
Please advise.
rudolphhsueh
Hi Sumankumar,
     we meet the same issue. Does PN7150 work on Android 13 ? Thanks.
danielchen
I am afraid not,  theoretically, you can port it by yourself.
