PN7120 Drivers porting in Android 4.4.2
sai_jagini
We are using android kitkat version 4.4.2 but NFC card supports and the steps in the manual ( NXPNCI Android Porting Guidelines ) are given as per android kitkat version 4.4.4 so i require android  NFC source and steps for enabling NFC for android kitkat version 4.4.2.
While building we got certain issue attached the following screenshot,
Refered Document Procedure:  AN11690.pdf
ISSUE
find: 'src' no such file or directory.
jimmychan
Although the steps in AN11690 is for kitkat version 4.4.4, the steps should be similar to the 4.4.2.
Please double check the steps you have followed in AN11690 and not missed any setting.
Please check the error is from the NFC driver?? or other makefile?
