PN544 with Android porting
2,930件の閲覧回数
jamesko
I have a question regarding PN544 (or PN532).
I am working on "AN11690 NXPNCI Android Porting Guidelines" and I get an error and ask for help.
Page 10,  3.2.1 Step 1: retrieving NXP-NCI NFC delivery
"$ wget https://raw.githubusercontent.com/NXPNFCLinux/nxpnfc_android_lollipop/master/nxpnfc_manifest.xml"
This will download the nxpnfc_manifest.xml file in the current directory.
Next, when you run this part
"& mv nxpnfc_manifest.xml  {ANDROID_BUILD_TOP} /. repo / local_manifests/"
"&" syntax error occurred.
With the exception of  "&"
"mv nxpnfc_manifest.xml {ANDROID_BUILD_TOP} /. Repo / local_manifests"
Error message  "There is no such file or folder"
What is the problem?
Thank you in advance for your help.
James
2,154件の閲覧回数
Kan_Li
Hi James Ko,
If you have downloaded nxpnfc_manifest.xml, the problem might be there is no folder named as "{ANDROID_BUILD_TOP} /. Repo / local_manifests", Have you already setup your PC for Android build? If not, you might have to do it at first. Please kindly refer to Establishing a Build Environment | Android Open Source Project for details.
Hope that helps,
Kan
