PN532 Plug n Play to PC (Win or Linux)
9,994件の閲覧回数
charles7
Noobie
I would like to set up PN532 for a model railroad project.  For id of rolling stock by location.
Need advice the most simplest method of interfacing PN532 (and multiple instances of PN532) to PC and MS  Excel on PC.  Using the simplest of I2C, SPI, or UART.  Direct to PC not  via micro.What software to set up.
Send me in the right direction to something similar set up already.
Thankyou
Charles Harris
9,860件の閲覧回数
Kan_Li
Hi Charles,
You may find the solution for PN532 in the following links:
https://www.nxp.com/docs/en/application-note/153910.pdf
https://www.nxp.com/downloads/en/design-support/123110.zip
https://www.nxp.com/downloads/en/nxp/libraries/NXP_RFID_213911.zip
and you may develop your own application based on SDK from https://www.nxp.com/downloads/en/software/NfcHAL_SDKv22_Setup_227122.rar , or use SCR Tester from https://www.nxp.com/downloads/en/software/141410.zip .
Hope that helps,
Kan
