PN5180 secure firmware
izmile
Where do I get NXP's secure firmware for PN5180? I searched docstore but could not locate any.
-Ismail
juergenschoeder
Hallo,
all firmware Versions of the PN5180 can be found on www.docstore.nxp.com (requires an NDA before access will be permitted)
The latest released version of the PN5180 Firmware is indeed part of the NFC Cockpit SW.
Hope this helps !
HeMyFAE
HI Ismail,
When you install cockpit SW, the secure FW in under the folder below:
C:\NXP\NxpNfcCockpit_v4.8.0.0\firmware\PN5180_SFWU
izmile
There is a firmware update library available but no links to the secure firmware. It did not surprise me that the firmware is not available on the public domain as it is as secure item. However, there should be some way of acquiring this. Appreciate any help in this regard.
-Ismail
stephanie_m
? Hello,
Sorry,  my bad for misunderstanding.
Could you please contact one of the Distributor Network|NXP  or an NXP es representative to seek for that access?
Estephania
stephanie_m
Have you checked the download tab in PN5180|NXP ?
Estephania
