NxpRdLib or NxpRdLibNet PCSC Example
moh_m
is there a complete example for using NxpRdLib/NxpRdLibNet with desfire EV1/EV2 Cards with/without SAM using a PCSC reader, the example should have creating Applications and Files and read/write them.
Jonathan_Iglesias
Hope you are doing great,
for PC/SC readers you can check the export controlled library and use it as reference since it is intended to work with our PEGODA reader, but this ( export controlled, SAM and DESFire)  is secured under NDA ( Non Disclosure Agreement) which means that all the information, tools and support should be delivered using secured communication channels and only to customers with active NDA.
 this is a public forum where we should not discuss  this type of topics. please contact your Distributos or NXP contact in order to get an NDA or the SW available in docsotre.
Have a great day!
Jonathan
