Need overview on PKI for SAM AV2 (MIFARE)
robneff
I'm doing some research on PKI, and in digging thru documentation I see descriptions of the PKI_ function calls, but I think I need to start with the big picture.  What components is it intended to encrypt communications for?  Is there a certificate authority being used?
I see references to it being used between the SAM AV2 and an NXP transceiver in x-mode, but is that the only intended use case?
Rob
