NTAG 5 Link Pin States
joshgott
I am currently using the NTAG5 Link (NTP53321G0JHKZ) for NFC energy harvesting. I am curious if there is a way to place the antenna connection pins ("LA" and "LB") into a High Z state during certain points in operation? I have tested to see if using Hard Power Down places those pins into a High Z state and it does not appear to do so.
Thank you!
Daniel_Gutierrez
Hello @joshgott, Good Day!
Thank you very much for your interest in our products.
I would like to ask in order to get a deeper understanding of the situation, what is the purpose of setting the LA/LB pins into a High Z state within the functionality of your system? Is it to disable the NFC interface?
My best regards,
Daniel.
