NT3H2211W0FT1X I2C not detecting with Raspberry Pi Model B.,I have connected I2C connection with my own NTAG pin out PCB setup .Circuit connection ,scl,sda(I2C-1 in Raspberry side),vcc,vss with Raspberry Pi pins.
1,420 次查看
vikaspot
标记 (1)
1,017 次查看
Kan_Li
Hi Vikas,
Have you ever probed the I2C-1 port during communication with NTAG? Did it receive the ACK signal from NTAG side? Please kindly help to clarify. Thanks for your patience!
Kan
