NFC card reading issue
Karyliu
Hi NXP,
The win10 machine is installed with NFC proximity driver and PC/SC driver, and uses NPC100 NFC IC.
The Type 1-5 card is written to the web address. When swiping the card on the machine, the web address interface can pop up, but there is no response when using PC/SC application to read the card.
The same TYPE1-5 card can read UID with the same PC/SC application on another machine.
What may be the cause?
thank you.
kary
