NFC antenna tool problem
2,287件の閲覧回数
hanpengfei_666
I use NFC antenna tool . In this design tool, the lenght(amax) is  board or  the periphery of the line?
2,147件の閲覧回数
Kan_Li
The amax and bmax are parameters for the size of the rectangle antenna, please refer to 3.1.1.1 Rectangular antenna calculations in https://www.nxp.com/docs/en/application-note/AN12334.pdf  for more details.
Hope that helps,
Kan
