NFC Reader Library for Linux
2,169件の閲覧回数
lwz
NFC Reader Library for Linux Installation in iso15693 examples, /_build/NfcrdlibEx5_ISO15693 make file ,have error messages: 1, /home/pi/cr663/_build/NfcrdlibEx5_ISO15693/NfcrdlibEx5_ISO15693.c:209:44: error: ?hacDiscLoop_Sw_DataParams_t??{aka ?truct phacDiscLoop_Sw_DataParams? has no member named ?TypeVTargetInfo?? did you mean ?TypeATargetInfo?? phApp_Print_Buff(sDiscLoop.sTypeVTargetInfo.aTypeV[0].aUid, 0x08); ^~~~~~~~~~~~~~~~ sTypeATargetInfo 2,/home/pi/cr663/_build/NfcrdlibEx5_ISO15693/NfcrdlibEx5_ISO15693.c:212:48: error: ?hacDiscLoop_Sw_DataParams_t??{aka ?truct phacDiscLoop_Sw_DataParams? has no member named ?TypeVTargetInfo?? did you mean ?TypeATargetInfo?? memcpy(aReceivedUid, sDiscLoop.sTypeVTargetInfo.aTypeV[0].aUid, 0x08); ^~~~~~~~~~~~~~~~ sTypeATargetInfo /home/pi/cr663/_build/NfcrdlibEx5_ISO15693/NfcrdlibEx5_ISO15693.c:209:44: error: ?hacDiscLoop_Sw_DataParams_t??{aka ?truct phacDiscLoop_Sw_DataParams? has no member named ?TypeVTargetInfo?? did you mean ?TypeATargetInfo?? phApp_Print_Buff(sDiscLoop.sTypeVTargetInfo.aTypeV[0].aUid, 0x08); ^~~~~~~~~~~~~~~~ sTypeATargetInfo /home/pi/cr663/_build/NfcrdlibEx5_ISO15693/NfcrdlibEx5_ISO15693.c:212:48: error: ?hacDiscLoop_Sw_DataParams_t??{aka ?truct phacDiscLoop_Sw_DataParams? has no member named ?TypeVTargetInfo?? did you mean ?TypeATargetInfo?? memcpy(aReceivedUid, sDiscLoop.sTypeVTargetInfo.aTypeV[0].aUid, 0x08); ^~~~~~~~~~~~~~~~ sTypeATargetInfo /home/pi/cr663/_build/NfcrdlibEx5_ISO15693/NfcrdlibEx5_ISO15693.c:215:51: error: ?hacDiscLoop_Sw_DataParams_t??{aka ?truct phacDiscLoop_Sw_DataParams? has no member named ?TypeVTargetInfo?? did you mean ?TypeATargetInfo?? if (DisplayCardTypeInfo(sDiscLoop.sTypeVTargetInfo.aTypeV[0].aUid) == PH_ERR_SUCCESS) ^~~~~~~~~~~~~~~~ sTypeATargetInfo /home/pi/cr663/_build/NfcrdlibEx5_ISO15693/NfcrdlibEx5_ISO15693.c:226:34: warning: implicit declaration of function ?halI15693_ReadSingleBlock?? did you mean ?halT1T_Sw_ReadBlock?? [-Wimplicit-function-declaration] status = phalI15693_ReadSingleBlock(&salI15693, ^~~~~~~~~~~~~~~~~~~~~~~~~~ phalT1T_Sw_ReadBlock /home/pi/cr663/_build/NfcrdlibEx5_ISO15693/NfcrdlibEx5_ISO15693.c:226:62: error: ?alI15693??undeclared (first use in this function) status = phalI15693_ReadSingleBlock(&salI15693, ^~~~~~~~~ /home/pi/cr663/_build/NfcrdlibEx5_ISO15693/NfcrdlibEx5_ISO15693.c:226:62: note: each undeclared identifier is reported only once for each function it appears in /home/pi/cr663/_build/NfcrdlibEx5_ISO15693/NfcrdlibEx5_ISO15693.c:227:29: error: ?HAL_I15693_OPTION_OFF??undeclared (first use in this function); did you mean ?HALI15693_H?? PHAL_I15693_OPTION_OFF, ^~~~~~~~~~~~~~~~~~~~~~ PHALI15693_H /home/pi/cr663/_build/NfcrdlibEx5_ISO15693/NfcrdlibEx5_ISO15693.c:250:34: warning: implicit declaration of function ?halI15693_WriteSingleBlock?? did you mean ?halT1T_Sw_WriteEraseBlock?? [-Wimplicit-function-declaration] status = phalI15693_WriteSingleBlock(&salI15693, ^~~~~~~~~~~~~~~~~~~~~~~~~~~ phalT1T_Sw_WriteEraseBlock /home/pi/cr663/_build/NfcrdlibEx5_ISO15693/NfcrdlibEx5_ISO15693.c:285:30: warning: implicit declaration of function ?hpalSli15693_Inventory??[-Wimplicit-function-declaration] status = phpalSli15693_Inventory(sDiscLoop.pPalSli15693DataParams, ^~~~~~~~~~~~~~~~~~~~~~~ /home/pi/cr663/_build/NfcrdlibEx5_ISO15693/NfcrdlibEx5_ISO15693.c:286:26: error: ?HPAL_SLI15693_FLAG_NBSLOTS??undeclared (first use in this function); did you mean ?HPALSLI15693_H?? (PHPAL_SLI15693_FLAG_NBSLOTS | PHPAL_SLI15693_FLAG_DATA_RATE | PHPAL_SLI15693_FLAG_INVENTORY), ^~~~~~~~~~~~~~~~~~~~~~~~~~~ PHPALSLI15693_H /home/pi/cr663/_build/NfcrdlibEx5_ISO15693/NfcrdlibEx5_ISO15693.c:286:56: error: ?HPAL_SLI15693_FLAG_DATA_RATE??undeclared (first use in this function); did you mean ?HPAL_I14443P4A_DATARATE_106?? (PHPAL_SLI15693_FLAG_NBSLOTS | PHPAL_SLI15693_FLAG_DATA_RATE | PHPAL_SLI15693_FLAG_INVENTORY), ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~ PHPAL_I14443P4A_DATARATE_106 /home/pi/cr663/_build/NfcrdlibEx5_ISO15693/NfcrdlibEx5_ISO15693.c:286:88: error: ?HPAL_SLI15693_FLAG_INVENTORY??undeclared (first use in this function) (PHPAL_SLI15693_FLAG_NBSLOTS | PHPAL_SLI15693_FLAG_DATA_RATE | PHPAL_SLI15693_FLAG_INVENTORY), ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~ make[2]: *** [NfcrdlibEx5_ISO15693/CMakeFiles/NfcrdlibEx5_ISO15693.dir/build.make:63: NfcrdlibEx5_ISO15693/CMakeFiles/NfcrdlibEx5_ISO15693.dir/NfcrdlibEx5_ISO15693.c.o] Error 1 make[1]: *** [CMakeFiles/Makefile2:2641: NfcrdlibEx5_ISO15693/CMakeFiles/NfcrdlibEx5_ISO15693.dir/all] Error 2 make: *** [Makefile:84: all] Error 2
2,037件の閲覧回数
jimmychan
Sorry, I cannot understand your question.
Could you tell me which example you ran?
Or tell me the steps what you did so I can try to reproduce the issue on my side.
Thanks.
