NFC Antenna design using External Antenna
ajit5wadekar
I am using PN7462 (https://www.nxp.com/products/rfid-nfc/nfc-hf/nfc-readers/nfc-cortex-m0-all-in-one-microcontroller-wi... for one of my design, here I need to use an external antenna, so I am planning to use the following Molex Antenna
https://www.molex.com/molex/products/part-detail/antennas/1462362131
For this I would like to understand the design consideration that I should consider while using above the antenna, and what should be the matching antenna circuit for the same.
Ajit Wadekar
stephanie_m
I apologize for the inconvenience this might cause you but there is really few information on how to use an external antenna and it can't be share in this public way. I apologize for the inconvenience this migth cause you.
regards,
Estephania
