Mifare Block emulation
michaeltrieglaff
is it possible to emulate a mifare block with PNEV512B Blueboard and LPCXpresso1769?
I can send and receive SAK and ATQA commands but got stuck in manipulating data in a mifare block.
I have tried NDEF-Messages but with no succes. Is there another way to write data in a block?
Thanks in advance
Michael
Labels (2)
Kan_Li
Hi Michael,
We provide NfcrdlibEx8_HCE_T4T demo in the NFC reader library(NFC Reader Library v4.040.05.011646 R1 for PNEV512B including all software examples. ), you may use it as a starting point.
Hope that helps,
Kan
