Make nfc tag read only command
2,693件の閲覧回数
thanosxenos
I am using element14 nfc board in my raspberry.
I have installed correctly all the commands but the documentation doesnt inlcude any command in order to program a tag to be read only.
Can you help me with that?
2,292件の閲覧回数
weidong_sun
Hello thanos ,
      Because differenct type of tags support different command, you will have to read the documentation of tags at first and make sure what commands it supports.
      In additon , the following is links for element14 nfc board:
(1)Here is software or example code
EXPLORE-NFC - Exclusive from element14|NXP
(2) documentation for board
(3)PN512's documentation / software & tools
PN512|NXP
    Hope above information can help you!
Weidong
