MFRC630 Communication Error
shabeebav
I am working on MFRC630 proto design, I could not communicate with MFRC630 with a UART interface. I have tested other related portions like crystal etc..which is working good. Signals from the communication port also working fine. Could some one suggest me the solution for this.
Thanks in Advance
IvanRuiz
Please refer to the software section in which you will find the PCSerial, SW tool in the software & tools tab. This tool will allow you to test the serial RS232 communication:
MFRC630 plus|NXP
I hope this helps.
Ivan.
