MFRC522 strange behaviour
3,041件の閲覧回数
dietrichwall
I have to implement an authentication application with an MFRC522 ver 02 Mifare reader. The reader is connected via I2C to a MSP430 Microcontroller. The first tests were successfull, i´m able to read the Version register. But reading other registers returns values which are not documented in this way. For example: reading the CommandReg register returns 0x3F, Datasheet mentions a reset value of 0x20.
Write accesses into internal Registers are also accepted and acknowledged from the chip. But when i´m trying to read out the written values, the initial values do not change.
The only register value that seems to be ok is the VersionReg Register(Adress: 0x37, Value 0x92)
What could be the reason for this behaviour?
Thx in advance
Dietrich
4 返答(返信)
2,712件の閲覧回数
Kan_Li
Hi Dietrich,
Would you please give a register dump from your side? and have you sent any command to RC522 before the reading? Please kindly help to clarify. Thanks for your patience!
Kan Li
2,712件の閲覧回数
dietrichwall
Hi Kan_Li,
I´ve made 3 Register Dumps. One before writing Reset Command in Commandregister, one right after writing it and the third with a delay of 1 second between the Reset command and reading the registers. The values are hexadezimal notated without leading zeros. Unfortunately I do not understand how to upload files in this forum, so I have to paste data as text.
Before Reset:
Reg: 0, Val: 0
Reg: 1, Val: 3f
Reg: 2, Val: 80
Reg: 3, Val: 0
Reg: 4, Val: 0
Reg: 5, Val: 8
Reg: 6, Val: 0
Reg: 7, Val: 28
Reg: 8, Val: 0
FIFO 0: 31
FIFO 1: 31
FIFO 2: 31
FIFO 3: 31
FIFO 4: 31
FIFO 5: 31
FIFO 6: 31
FIFO 7: 31
FIFO 8: 31
FIFO 9: 31
FIFO 10: 31
FIFO 11: 31
FIFO 12: 31
FIFO 13: 31
FIFO 14: 31
FIFO 15: 31
FIFO 16: 31
FIFO 17: 31
FIFO 18: 31
FIFO 19: 31
FIFO 20: 31
FIFO 21: 31
FIFO 22: 31
FIFO 23: 31
FIFO 24: 31
FIFO 25: 31
FIFO 26: 31
FIFO 27: 31
FIFO 28: 31
FIFO 29: 31
FIFO 30: 31
FIFO 31: 31
FIFO 32: 31
FIFO 33: 31
FIFO 34: 31
FIFO 35: 31
FIFO 36: 31
FIFO 37: 31
FIFO 38: 31
FIFO 39: 31
FIFO 40: 31
FIFO 41: 31
FIFO 42: 31
FIFO 43: 31
FIFO 44: 31
FIFO 45: 31
FIFO 46: 31
FIFO 47: 31
FIFO 48: 31
FIFO 49: 31
FIFO 50: 31
FIFO 51: 31
FIFO 52: 31
FIFO 53: 31
FIFO 54: 31
FIFO 55: 31
FIFO 56: 31
FIFO 57: 31
FIFO 58: 31
FIFO 59: 31
FIFO 60: 31
FIFO 61: 31
FIFO 62: 31
FIFO 63: 31
Reg: a, Val: 0
Reg: b, Val: 8
Reg: c, Val: 34
Reg: d, Val: 0
Reg: e, Val: a5
Reg: f, Val: 0
Reg: 10, Val: 0
Reg: 11, Val: 3f
Reg: 12, Val: 0
Reg: 13, Val: 0
Reg: 14, Val: 80
Reg: 15, Val: 0
Reg: 16, Val: 10
Reg: 17, Val: 84
Reg: 18, Val: 84
Reg: 19, Val: 4d
Reg: 1a, Val: 0
Reg: 1b, Val: 0
Reg: 1c, Val: 62
Reg: 1d, Val: 0
Reg: 1e, Val: 0
Reg: 1f, Val: eb
Reg: 20, Val: 0
Reg: 21, Val: fb
Reg: 22, Val: ff
Reg: 23, Val: 88
Reg: 24, Val: 26
Reg: 25, Val: 87
Reg: 26, Val: 48
Reg: 27, Val: 88
Reg: 28, Val: 20
Reg: 29, Val: 20
Reg: 2a, Val: 0
Reg: 2b, Val: 0
Reg: 2c, Val: 0
Reg: 2d, Val: 0
Reg: 2e, Val: e0
Reg: 2f, Val: a6
Reg: 30, Val: 0
Reg: 31, Val: 0
Reg: 32, Val: 0
Reg: 33, Val: 80
Reg: 34, Val: 0
Reg: 35, Val: 4
Reg: 36, Val: 40
Reg: 37, Val: 92
Reg: 38, Val: 0
Reg: 39, Val: 24
Reg: 3a, Val: 0
Reg: 3b, Val: 0
Reg: 3c, Val: ff
Reg: 3d, Val: 0
Reg: 3e, Val: 3
Reg: 3f, Val: 0
After Reset no delay:
Reg: 0, Val: 0
Reg: 1, Val: 3f
Reg: 2, Val: 80
Reg: 3, Val: 0
Reg: 4, Val: 74
Reg: 5, Val: c
Reg: 6, Val: 0
Reg: 7, Val: 25
Reg: 8, Val: 4
FIFO 0: 0
FIFO 1: 0
FIFO 2: 0
FIFO 3: 0
FIFO 4: 0
FIFO 5: 0
FIFO 6: 0
FIFO 7: 0
FIFO 8: 0
FIFO 9: 0
FIFO 10: 0
FIFO 11: 0
FIFO 12: 0
FIFO 13: 0
FIFO 14: 0
FIFO 15: 0
FIFO 16: 0
FIFO 17: 0
FIFO 18: 0
FIFO 19: 0
FIFO 20: 0
FIFO 21: 0
FIFO 22: 0
FIFO 23: 0
FIFO 24: 0
FIFO 25: 0
FIFO 26: 0
FIFO 27: 0
FIFO 28: 0
FIFO 29: 0
FIFO 30: 0
FIFO 31: 0
FIFO 32: 0
FIFO 33: 0
FIFO 34: 0
FIFO 35: 0
FIFO 36: 0
FIFO 37: 0
FIFO 38: 0
FIFO 39: 0
FIFO 40: 0
FIFO 41: 0
FIFO 42: 0
FIFO 43: 0
FIFO 44: 0
FIFO 45: 0
FIFO 46: 0
FIFO 47: 0
FIFO 48: 0
FIFO 49: 0
FIFO 50: 0
FIFO 51: 0
FIFO 52: 0
FIFO 53: 0
FIFO 54: 0
FIFO 55: 0
FIFO 56: 0
FIFO 57: 0
FIFO 58: 0
FIFO 59: 0
FIFO 60: 0
FIFO 61: 0
FIFO 62: 0
FIFO 63: 0
Reg: a, Val: 0
Reg: b, Val: 8
Reg: c, Val: 30
Reg: d, Val: 0
Reg: e, Val: a0
Reg: f, Val: 0
Reg: 10, Val: 0
Reg: 11, Val: 3f
Reg: 12, Val: 0
Reg: 13, Val: 0
Reg: 14, Val: 80
Reg: 15, Val: 0
Reg: 16, Val: 10
Reg: 17, Val: 84
Reg: 18, Val: 84
Reg: 19, Val: 4d
Reg: 1a, Val: 0
Reg: 1b, Val: 0
Reg: 1c, Val: 66
Reg: 1d, Val: 0
Reg: 1e, Val: 0
Reg: 1f, Val: eb
Reg: 20, Val: 0
Reg: 21, Val: 62
Reg: 22, Val: 3a
Reg: 23, Val: 88
Reg: 24, Val: 26
Reg: 25, Val: 87
Reg: 26, Val: 48
Reg: 27, Val: 88
Reg: 28, Val: 20
Reg: 29, Val: 20
Reg: 2a, Val: 0
Reg: 2b, Val: 0
Reg: 2c, Val: 0
Reg: 2d, Val: 0
Reg: 2e, Val: 0
Reg: 2f, Val: 0
Reg: 30, Val: 0
Reg: 31, Val: 0
Reg: 32, Val: 0
Reg: 33, Val: 80
Reg: 34, Val: 0
Reg: 35, Val: 9
Reg: 36, Val: 40
Reg: 37, Val: 92
Reg: 38, Val: 0
Reg: 39, Val: 24
Reg: 3a, Val: 0
Reg: 3b, Val: ff
Reg: 3c, Val: ff
Reg: 3d, Val: 0
Reg: 3e, Val: 3
Reg: 3f, Val: 0
After Reset with delay:
Reg: 0, Val: 0
Reg: 1, Val: 3f
Reg: 2, Val: 80
Reg: 3, Val: 0
Reg: 4, Val: 0
Reg: 5, Val: 8
Reg: 6, Val: 0
Reg: 7, Val: 28
Reg: 8, Val: 0
FIFO 0: 31
FIFO 1: 31
FIFO 2: 31
FIFO 3: 31
FIFO 4: 31
FIFO 5: 31
FIFO 6: 31
FIFO 7: 31
FIFO 8: 31
FIFO 9: 31
FIFO 10: 31
FIFO 11: 31
FIFO 12: 31
FIFO 13: 31
FIFO 14: 31
FIFO 15: 31
FIFO 16: 31
FIFO 17: 31
FIFO 18: 31
FIFO 19: 31
FIFO 20: 31
FIFO 21: 31
FIFO 22: 31
FIFO 23: 31
FIFO 24: 31
FIFO 25: 31
FIFO 26: 31
FIFO 27: 31
FIFO 28: 31
FIFO 29: 31
FIFO 30: 31
FIFO 31: 31
FIFO 32: 31
FIFO 33: 31
FIFO 34: 31
FIFO 35: 31
FIFO 36: 31
FIFO 37: 31
FIFO 38: 31
FIFO 39: 31
FIFO 40: 31
FIFO 41: 31
FIFO 42: 31
FIFO 43: 31
FIFO 44: 31
FIFO 45: 31
FIFO 46: 31
FIFO 47: 31
FIFO 48: 31
FIFO 49: 31
FIFO 50: 31
FIFO 51: 31
FIFO 52: 31
FIFO 53: 31
FIFO 54: 31
FIFO 55: 31
FIFO 56: 31
FIFO 57: 31
FIFO 58: 31
FIFO 59: 31
FIFO 60: 31
FIFO 61: 31
FIFO 62: 31
FIFO 63: 31
Reg: a, Val: 0
Reg: b, Val: 8
Reg: c, Val: 34
Reg: d, Val: 0
Reg: e, Val: a5
Reg: f, Val: 0
Reg: 10, Val: 0
Reg: 11, Val: 3f
Reg: 12, Val: 0
Reg: 13, Val: 0
Reg: 14, Val: 80
Reg: 15, Val: 0
Reg: 16, Val: 10
Reg: 17, Val: 84
Reg: 18, Val: 84
Reg: 19, Val: 4d
Reg: 1a, Val: 0
Reg: 1b, Val: 0
Reg: 1c, Val: 62
Reg: 1d, Val: 0
Reg: 1e, Val: 0
Reg: 1f, Val: eb
Reg: 20, Val: 0
Reg: 21, Val: fb
Reg: 22, Val: ff
Reg: 23, Val: 88
Reg: 24, Val: 26
Reg: 25, Val: 87
Reg: 26, Val: 48
Reg: 27, Val: 88
Reg: 28, Val: 20
Reg: 29, Val: 20
Reg: 2a, Val: 0
Reg: 2b, Val: 0
Reg: 2c, Val: 0
Reg: 2d, Val: 0
Reg: 2e, Val: e0
Reg: 2f, Val: a6
Reg: 30, Val: 0
Reg: 31, Val: 0
Reg: 32, Val: 0
Reg: 33, Val: 80
Reg: 34, Val: 0
Reg: 35, Val: 4
Reg: 36, Val: 40
Reg: 37, Val: 92
Reg: 38, Val: 0
Reg: 39, Val: 24
Reg: 3a, Val: 0
Reg: 3b, Val: 0
Reg: 3c, Val: ff
Reg: 3d, Val: 0
Reg: 3e, Val: 3
Reg: 3f, Val: 0
2,712件の閲覧回数
Kan_Li
Hi Dietrich,
Thanks for the information! I am checking with our AE team for this issue, and will let you know when I have any more information.
Kan
2,712件の閲覧回数
dietrichwall
Hi Kan_Li,
Thanks for your efforts, we have found the reason for this. It was a wrong placed oscilator on the PCB. Which seems also to describe the read register values.
Dietrich
