Java Example for Mikroe NFC USB Dongle (NXP PN7150)
ソリューションへジャンプ
4,710件の閲覧回数
marc1
I just bought the Mikroe NFC USB Dongle (with NXP PN7150). It is provided with a C example software (Here: http://www.nxp.com/documents/software/SW4335.zip). Do you know if there would be a Java one? It would be very much easier for me.
Thank you !
Marc
4,559件の閲覧回数
stephanie_m
Sorry but we do not have a java code for the board you mention, you will need to migrate your code to the code language.
You can try some of the porting guidelines available in this link and verify f those help you in your development.
Estephania
3 返答(返信)
4,559件の閲覧回数
stephanie_m
Estephania
4,559件の閲覧回数
marc1
Thank you for the link. It helped. :smileyhappy:
4,559件の閲覧回数
jibran
Hi, I think i'm also trying to do the same thing as you. However, im a bit stuck on where the drivers for each should end up. Should the kernel drivers end up in the Android device or should all of the required porting be only inside the app?
Kind regards,
Jibran
